headlights "hiccup" when engine shuts off:
Old Dec 2, 2012 | 01:19 PM
Uncle Maddog's Avatar
Uncle Maddog
Default headlights "hiccup" when engine shuts off:
Has anyone ever had the headlights "hiccup" when the engine shuts off? Other lift functions are correct, but when I turn off the engine with doors down, they pop up slightly, then drop back to their normal closed position. This all takes less than a couple of seconds. I haven't checked the vacuum check valve yet, but that may be the culprit. Any thoughts? Thanks, everybody!
Old Dec 2, 2012 | 02:38 PM
Alan 71's Avatar
Alan 71
Hi um,
Your problem could well be the check valve.
When the lights wink or nod it's often because there's a small leak in the control, (small hose), side of the vacuum system.
After checking the valve I'd look at at the hose connections at the headlight relays, and then the function of the relays, the headlight switch, and the over-ride switch.
If the hoses are original or quite old often cutting about 3/8" off the ends gives you a fresh seal.
Good Luck!
Regards,
Alan
Old Dec 2, 2012 | 03:21 PM
Uncle Maddog
Default headlight hiccups:
Thanks, Alan, for the quick reply. I'm sure it's an easy fix, I've been through two other of thes C3s before now, I just hadn't had the "hiccups" with them (unless it was a five beer job). I'll keep looking, and remember: "a wink is as good as a nod to a blind horse" Best regards........
Old Dec 2, 2012 | 03:41 PM
ramair_bryan's Avatar
ramair_bryan
cool............how can i make mine do that?.......
Old Dec 6, 2012 | 07:39 AM
Uncle Maddog
Default hiccups:
Turned out to be the check valve! Thanks, everybody for your interest.
To headlights "hiccup" when engine shuts off:
