Frozen bleeder screws?
Old Jun 9, 2002 | 01:01 AM
Buffalo Dude's Avatar
Buffalo Dude
St. Jude Donor '07
Default Frozen bleeder screws?
I'm going to be flushing my brakes system soon(my first time :crazy: ) and they haven't been bleed in a few years. Is it possible the bleeder screws are frozen right now and should I use a little wd40 now so it'll go smoothly when I get to it? If not WD40, then what else can I use?
Old Jun 9, 2002 | 02:12 AM
R. Bruno's Avatar
R. Bruno
Default Re: Frozen bleeder screws? (Buffalo Dude)
PB Blaster is vastly superior to WD-40. Its available at auto chain stores. WD_40 has its place, for me mostly cleaning and lubricating , but since being introduced to PB by someone on the forum, I am sold on the stuff to use to free-up nuts and bolts..
Old Jun 9, 2002 | 02:51 AM
Stevo81's Avatar
Stevo81
Yes. Bruno is right. Blaster is the answer. Maybe even a couple applications in the weeks preceeding everyones favorite job. And a good wrench so as to not round off the little dude. I put speed bleeders in, makes it a little easier.
Old Jun 9, 2002 | 02:58 AM
Rockn-Roll's Avatar
Rockn-Roll
Bleeders rarely get frozen unless someone puts something on the threads. The bleeders are designed to be tightened about 25inlbs and stay there for almost a decade without a problem. Though it would not hurt to soak them with a lubricant, just try not to get any on the pads.
Old Jun 9, 2002 | 07:18 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Default Re: Frozen bleeder screws? (Rockn-Roll)
Also, use a 6 point socket or wrench, not a 12 point. Chuck
Old Jun 9, 2002 | 10:52 AM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
use a motorcycle type impact tool the loosen them up. this is the type you hit with a hammer and the shock will loosen the bleeder. :chevy
Old Jun 10, 2002 | 03:06 AM
Buffalo Dude
St. Jude Donor '07
Thanks guys, i'll go pick some up tomorrow :chevy
Old Jun 10, 2002 | 03:33 AM
PrarieShark's Avatar
PrarieShark
From: The cure for the blues is eight cylinders roaring
Also get lenght of clear plastic hose like what is used in fishtanks. Fit one end on the bleeder niple and put the other end in a nearly empty bottle of break fluid. This way you can bleed your breaks on your own. the hose is also sold in break bleeding kits at any parts store.
FYI buy at least two large botles of break fluid to flush the system.
Old Jun 10, 2002 | 09:37 AM
lyonsh's Avatar
lyonsh
Default Re: Frozen bleeder screws? (clem zahrobsky)
Another method is to put a deep socket of the right size over the bleeder and give it a few sharp taps with a hammer. I've had several frozen bleeders loosen up this way - the tapping is just enough to loosen the rust that works its way in (probably from water in the system).
Old Jun 11, 2002 | 12:53 AM
Buffalo Dude
St. Jude Donor '07
Default Re: Frozen bleeder screws? (Wightnite)
Looks like more stuff to pick up :crazy: Thanks guys, you've been a big help. I'll start as soon as the gasket for my tranny arrives. Looks like I'll be busy this summer :yesnod: :chevy
To Frozen bleeder screws?
