VIN numbers / matching numbers.
Old Dec 3, 2012 | 03:50 PM
Glarsen's Avatar
Glarsen
6th Gear
Default VIN numbers / matching numbers.
Hi
I just bought a 72 454 convertible, auto transmission, and I have a question about this issue with matching numbers. The car I bought was sold as a "matching numbers" car, wich for me is the correct numbers on the frame, engine and gearbox. But the thing is, how can I check its actually the original numbers? Are the numbers identical or are they linked to eachother somehowe, so I can tell by looking at them? Maybe I have to look into some kind of a register from the time the car left the factory?
Old Dec 3, 2012 | 04:25 PM
Jig A Low's Avatar
Jig A Low
I'm not an expert by any stretch but I believe the numbers stamped on the various parts should match the last 5 or 6 numbers of the VIN#
Old Dec 3, 2012 | 04:39 PM
MelWff's Avatar
MelWff
the engine pad on the passenger side should have the last 6 digits of your vin plus the engine code should be appropriate for the engine size/options/year. I believe the trani also has the partial vin on it. If you do a search within this forum you will find the complete criteria.
Old Dec 3, 2012 | 04:42 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
No disrespect, but checking numbers after purchase is risky behaviour.
The engine code and VIN derivitive are stamped on a pad on the block at the front of the passenger's head. Jot down both stampings. This is a small block, but big blocks are similar.
A VIN derivitive is stamped on the frame at two locations. The first is on top of the frame rail about where your left hip will be if you are sitting in the car. You cannot see this stamp with the body on the frame.
The second location is on the also on the top of the frame rail, also driver's side just in front of the #4 body mount. Some people can see this number; others cannot.
If memory serves, the VIN derivitive is stamped on the tag for TH400s.
Old Dec 3, 2012 | 06:19 PM
Alan 71's Avatar
Alan 71
Hi G,
I'll just add that the vin derivative stamp on the transmission case was usually done with the same stamp and by the same person as the stamp on the engine pad. So the 2 should show the same characteristics. Such as the shape of the digits (6s and 0s often varied in shape).
Regards,
Alan
Old Dec 3, 2012 | 08:02 PM
AirborneSilva's Avatar
AirborneSilva
you can kinda see the vin stamped on my tranny, it's in the middle of the picture.
Old Dec 15, 2012 | 04:28 AM
Glarsen's Avatar
Glarsen
6th Gear
Thanx for the answers. It really helps when pics are posted, sooo much easier to find and understand where to look. Well, I found all the numbers on my car, and they are matching
Old Dec 15, 2012 | 07:44 AM
redrdstr72's Avatar
redrdstr72
Hi Glarsen. You've gotten some very good and informative responses here.
Don't forget that the VIN is also on your "A" pillar and in the blue certification label, which should be on the trailing edge of your LH door.
"Numbers matching" for me extends well beyond the VIN. Key components such as your diff case, starter motor, carb, alternator, distributor, etc all have car-specific part numbers and dates of manufacture that are critical if you plan to have you car judged by NCRS or Bloomington Gold.
If you don't have these references already, I urge you to invest in the NCRS Judging Guide, a Corvette Assembly Instruction Manual and a Chassis Service Manual for your year car. These are extremely valuable resources and will help you learn all the details of your new Corvette.
Old Dec 15, 2012 | 08:22 AM
Alan 71's Avatar
Alan 71
Hi,
I agree with rr72 that 'checking the numbers' can go far beyond the VIN tag, engine stamp pad, and transmission stamp.
Many, many, mechanical, chassis, exterior, and interior parts, had part numbers and dates that while not tying them to a particular car, can make them appropriate for a particular car.
I found it interesting to see that sometimes these date coded parts arrived at St.Louis just in the nick of time. So it seems there were not large amounts of stock at the plant. Many parts on my 71 are dated with-in just a few days or weeks of it's build date.
Even 'major' parts seem to have moved quickly. The cylinder case of the base engine in my car was cast on December 31st.; the engine was assembled on January 7th.; and was in the car on about January 15th.
Regards,
Alan
Old Dec 15, 2012 | 10:03 AM
redrdstr72's Avatar
redrdstr72
Alan's right on the money. Interestingly, my Flint Michigan-built engine was cast on August 11, 1971. It was built up and shipped to St. Louis in time for the August 23, 1971 vehicle assembly date. A total of just 7 work days before it went into the car.
I may have been a little misleading in my earlier post. By "car-specific", I meant part number and date "correct" for a particular vehicle type (small vs big block, AC, PS, PB, PW, etc). For example, an auto trans uses a different carb than a manual trans. An AC car uses a different alt than a non AC car. I hope this didn't cause any confusion or concern.
Old Dec 15, 2012 | 10:24 AM
Mike Ward's Avatar
Mike Ward
The only on going confusion is the assumption by many that's there's a set definition for the phrase 'matching numbers'.
Old Dec 15, 2012 | 11:36 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by Alan 71
...I found it interesting to see that sometimes these date coded parts arrived at St.Louis just in the nick of time. So it seems there were not large amounts of stock at the plant...
That is by design. The Corvette Building at the St. Louis facility was always and continually short of warehouse space. At no time did they ever have room to store any major quantity of parts. Frames and fiberglass were often stored outside. Existing assembly line photographs almost always show boxes and bins of parts stacked on both sides of the line.
To VIN numbers / matching numbers.
