vinyl wrap question
Old Dec 4, 2012 | 02:43 PM
7t9l82's Avatar
7t9l82
Default vinyl wrap question
i saw a car with a vinyl wrap that looked like chrome,and other finishes. i wonder if that could be applied to fiberglass side pipe covers. i know it would adhere just wonder around the fins etc. and durability. every option I've explored has been as much as the factory covers. any ideas?
Old Dec 4, 2012 | 03:31 PM
MelWff's Avatar
MelWff
Are you talking about factory style side exhaust or hooker style side exhaust? Either way wouldnt vinyl melt?
Old Dec 4, 2012 | 04:49 PM
Corey_68's Avatar
Corey_68
Yoy have to worry about the heat and just would be a nightmare to get the thick vinyl inside the grooves/fins of the OEM style covers.
Old Dec 4, 2012 | 06:16 PM
7t9l82's Avatar
7t9l82
well obviously the fiberglass reproduction covers , the hooker side mounts would be a mess
Old Dec 5, 2012 | 05:06 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
I'd talk to someone like Paul's Chrome. IIRC they "chrome" plastic stuff, but I don't know how the sidepipe covers would hold up, given the heat. Chrome mylar may or may not work either, but thought I'd mention it just in case.
Old Dec 5, 2012 | 06:32 PM
7t9l82's Avatar
7t9l82
pauls has done them they claim it holds up. however at over a thousand bucks its insane in my opinion, id rather get a new set from ecklers.just thought it may be an option. i will check a sign company i guess thanks .
Old Dec 5, 2012 | 08:03 PM
johnt365's Avatar
johnt365
My brother runs a production shop that installs these wraps on cars, walls etc. I asked him about the heat issue. He was unsure of any documented heat limitations. I asked what about excessive underhood temps and exhaust temps. He mentioned that Nascar uses this product on all the cars but more interesting is that when he installs the product, he uses a propane torch applied directly to the product to remove wrinkles. (short periods of time obviously)
I would try to go to a shop that installs this product and ask if they would be willing to give you a little scrap to apply as a test. They are going to throw it out anyway...
It is removable.
To vinyl wrap question
