Swirl marks under primer
Old Jun 9, 2002 | 02:29 PM
dewayne4
Default Swirl marks under primer
I have completely removed all of the paint and primer. In a few areas I have sanded to far, I think. There are swirly things that look like they are in the fiberglass. It is not scratches from sanding. What do I need to do with these markings. THey cannot be felt, but they are easily seen. Will this show up through the new paint??? :confused:
Old Jun 9, 2002 | 11:35 PM
CF6873's Avatar
CF6873
Default Re: Swirl marks under primer (dewayne4)
I'm not sure that I understand what it is that is under the primer, but as long as it is not contamination several coats of epoxy primer should seal it down. I would sand the area and recoat with more epoxy to make sure that it is sealed and won't show though the top coats. Good Luck, Craig
Old Jun 10, 2002 | 09:11 PM
dewayne4
Default Re: Swirl marks under primer (CF6873)
The swirly things look like the are in the fiberglass itself. I wish I had a digital camera, so I could show you.
Old Jun 10, 2002 | 09:19 PM
vert2go89's Avatar
vert2go89
Cruise-In I Veteran
I think what you are seeing is the fiberglass itself.You can't feel them but just see them right?When I stripped mine I could see them also but couldn't feel them.I just used sealer primer and none of that showed up thru paint.
Old Jun 10, 2002 | 09:55 PM
dewayne4
Default Re: Swirl marks under primer (all smiles 81)
You got it. But will they effect the paint in years to come?
:confused:
To Swirl marks under primer
