rotor run out???????
Old Jun 9, 2002 | 05:02 PM
Black&Silver78Pace's Avatar
Black&Silver78Pace
Default rotor run out???????
what is that need to replace bearing in rear looking to get complete rebuilt unit and just bolt new on to t.arm or go with whole new t arm and assembly
Old Jun 9, 2002 | 06:25 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
Default Re: rotor run out??????? (Black&Silver78Pace)
If you have the $$..go with a replacement assembly. You'll probably find the t-arm bushings and everything worn anyway. It's less a PIA to make an ssembly swap than all the components.
Old Jun 10, 2002 | 05:32 PM
Black&Silver78Pace
Default Re: rotor run out??????? (AlwaysWave)
make sense thanks still not sure of rotor run out they talk about when they mention rebuilt bearing assemblies they say they set them up to avoid that?????????????????????
Old Jun 10, 2002 | 09:18 PM
Barry's70LT1's Avatar
Barry's70LT1
http://forums.corvetteforum.com/zerothread?id=310349
To rotor run out???????
