Wheel Size (Again)
I'm looking at a set of 18" wheels for my 1978 SA. I've researched here on the forums, but I can't find a straight answer. The set I'm looking at is this:http://oewheelsllc.com/Wheels_3/Whee...heels-Chrome_3
What do I have do to make these wheels flush with the flares/fenders, and not rub? Thanks so much.
I've been searching so much stuff that my mind is just aching.
Thanks in advance!
-Damon
Those wheels need adapters to correct the backspace to work even if they did fit.
A 18X10.5" rear wheel won't fit. A 18x10 with a 5.5 backspace may fit. You might have interference with the edge of the rear spring, rear sway bar, or parking brake cable. A 18x9.5 with a 5" backspace and a 275/40 tire should fit with little to no issues. If you want to go with OEM type wheels and adapters consider 18x8.5 for the front and 18x9.5 for the rear. As you already know there is lots of reading on this. You can do a search using "adapters" and "18s" to get a better idea on what you want to do.
Each car is different, I have 285/40/17's on mine and they rub a tiny bit, you have an easier job fitting 18's than 17's as there's more things to foul with the 17. ( I had to move the handbrake bracket and get a shorter spring, but that's with 17's)
Go with the advice from the previous poster or copy something someone else has done
18x9.5 in back and 18.8.5 in front. I'd be running 275-40-18s in rear and 245s in front.
Rears: http://www.summitracing.com/parts/su...61c0/overview/
Fronts: http://www.summitracing.com/parts/su...1c10/overview/
Rears are 18x9.5 with 5.25 backspace.
Fronts are 18x8.5 with 5.125 backspace.
I'm hoping these are a bit better choice.
Thanks in advance!
-Damon
The rears should be OK.
The fronts I think still may be a little too deep.
Are you dead set on chrome? If you're on a tight budget and like the style of the 1st set of wheels you posted I think you would be better off with a set of OEM "take offs" in the correct widths and buy the correct size adapter to place the wheel where it needs to be in the wheel well. The quality of chrome on a wheel in this price range is not going to be that durable and will probably peel at some point. "Take offs" can be found at reasonable prices it you do your homework. Buy a quality set of adapters and you should be able to stay within your budget. Of course it's your car and you need to do what makes you happy. I'm just throwing out some alternatives.
I have a staggered set with 18x8.5 fronts and 18x10 rears. I would like to use 245/40 front and 285/35 rear...
And I'm guessing from what I've read that 5.125 BS is the best for an 18x8.5 and 5.5 BS is the best for an 18x10 rear?
Thanks--just confirming...
thanks
thanks
and 17 x 9.5" (5.25BS) and it's about as tight as it gets
You'll have more luck with the 18 as the trailing arm tapers away
I've heard 18 x 10 with a 5.5BS works but don't quote me....
Thanks in advance!
-Damon
I don't have anything yet.
But-- if I wanted an 18x8.5 front and 18x10 rear, I just wanted to know what would be the absolute optimum backspacing for those widths?? (Going on a 1970-72)
Thanks a ton.
