68 sun visor repair
Old Dec 11, 2012 | 05:03 AM
Crimson Ghost's Avatar
Crimson Ghost
Default 68 sun visor repair
Hello friends. I searched but did not find a thread on how to repair our sun visors. Can anyone assist me ?
My drivers side visor drop's badly and is in dire need of repair. Its condition is excellant so no need to replace, just fix. I found this on Ecklers:
http://www.ecklerscorvette.com/corve...pins-1968.html
is this what I need ? are there any DIY instructions around? or does anyone have any experiance?
Thanks !
Old Dec 11, 2012 | 12:27 PM
BB68Vett's Avatar
BB68Vett
The sun visors on my '68 don't use that type of mounting hardware. Mine is just a screw with some type of flat sheet metal speed nut on the back side. Lot's of running changes in the '68 model year.
No reason this woudn't work though. When my sunvisors get a little floppy, I just tighten the screws down a little, and that's it. Have you tried tightening the screws on your sunvisors? If they don't tighten, then they may be stripped and require replacement. This kit should work to solve the problem. Good luck.
Old Dec 11, 2012 | 01:37 PM
Rally68's Avatar
Rally68
I removed the visors from the car, loosened the screws in the visors and removed the hinge pins. I then slipped short sections of clear tubing (I forget the ID) over the pins where they fit inside the visors. I hit them momentarily with a heat gun to make them a tight fit, and then reassembled. That was probably 4 years ago and they've been like new ever since.
Old Dec 11, 2012 | 03:28 PM
BB68Vett's Avatar
BB68Vett
Rally68, that's a good fix! I'll have to remember that one, if I ever need it.
Old Dec 11, 2012 | 04:34 PM
Crimson Ghost
Thank you great idea !
To 68 sun visor repair
