Intake vacuum fitting. sealer?
Old Jun 10, 2002 | 10:52 AM
mayberg's Avatar
mayberg
Default Intake vacuum fitting. sealer?
Ladies and Gentlemen,
Once again, I've noticed a loose-fitting intake manifold vacuum fitting. So, I'm probably leaking vacuum and causing sub-par engine, auto-transmission and brake performance.
And, can you believe it, the fitting is cracked around the nipple for the transmission.
Since teflon tape won't work (yes, call me Bubba) then what does one use to seal this fitting to the intake manifold? I haven't yet checked my shop manual. Do you just wrench it down tight? Or do you put a bit of the sealer goo on it?
Your kind consideration and generous expertise is appreciated. Thanks, GM
Old Jun 10, 2002 | 06:04 PM
Kingt's Avatar
Kingt
Default Re: Intake vacuum fitting. sealer? (mayberg)
Loc-tite makes a prodcut called PST (pipe sealant with teflon) works good on vacuum fittings.
Old Jun 11, 2002 | 12:51 AM
CDaniel525's Avatar
CDaniel525
Default Re: Intake vacuum fitting. sealer? (Kingt)
getting a new fitting would be best, but a liquid sealer like Kingt said us better than teflon tape. I use something called Leak Lock that you can pick up at any plumbing supply...just tell them you need a sealer for NPT fittings
[Modified by 74VETTE, 11:54 PM 6/10/2002]
To Intake vacuum fitting. sealer?
