82 corvette head lights
Old Dec 15, 2012 | 05:53 PM
82 corvette's Avatar
82 corvette
Default 82 corvette head lights
Does anyone know if there is a conversion kit to turn my vaccume driven head lights into a motor driven set up.
Old Dec 15, 2012 | 06:14 PM
7t9l82's Avatar
7t9l82
do a search there are at least a couple out there. why not fix the factory system, they are not complicated
Old Dec 15, 2012 | 06:16 PM
MelWff's Avatar
MelWff
here you go
http://www.ecklerscorvette.com/corve...1980-1982.html
Old Dec 15, 2012 | 06:19 PM
DUB's Avatar
DUB
Yes...one of my customers has it on his 1977. They work but seem to me...to be a bit un-attractive....and could use some dampening with rubber stops so it is not so "clanky" sounding. I doubt that he would know where they came from...due to he bought the car that way ( already converted)
And for what it is worth...the cost of changing over the system may be more costly than fixing what you have...if your system is complete now. Running wire harness, drilling holes, mounting relays, etc....not including setting up the motors to your actuator supports could be labor intensive
DUB
Old Dec 15, 2012 | 06:21 PM
Peterbuilt's Avatar
Peterbuilt
And it will cost a lot less then $999.99
Old Dec 15, 2012 | 07:52 PM
82 corvette
Default 82 head lights
thanks for the response, mine are definitly not working and i was looking to see if it would be a cheap conversion but it looks pricey. I think i will be looking into fixing the vaccume system. Was hoping to clean up under the hood by getting rid of the canisters and vaccume lines.
Old Dec 15, 2012 | 07:54 PM
82 corvette
Old Dec 15, 2012 | 08:24 PM
MIKE80's Avatar
MIKE80
I'm converting mine to electric. I already have all the parts I need. Just need the time to do it. When I get my old vacuum parts out, which are all pretty much new/ barely used, I'll be selling them.
Old Dec 15, 2012 | 08:27 PM
82 corvette
Default 82 corvette
What did all the parts cost ya and where did you order them from.
To 82 corvette head lights
