1980 door lock problems/intake problems
Old Dec 15, 2012 | 09:46 PM
preston1967's Avatar
preston1967
Cruising
Default 1980 door lock problems/intake problems
OK, saved a beautiful shark from goint to the boneyard. In trying to get this thing back the way it should be am of course running into a few probs.
1. elect. door locks. replaced everything, still doesnt work. have voltage to one side of the plug when the switch is depressed and to the other side when it is depressed the other way. Is this correct?
2. Had a dual snorkel original intake with the car. The side cold air tube was mounted. Missing the front , so I bought one. Hood will not close with it in place. I know the car is an L48. Is there a different radiator setup needed to get clearance for the dual snorkel cold air?
Old Dec 16, 2012 | 10:51 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by preston1967
...Is there a different radiator setup needed to get clearance for the dual snorkel cold air?...
No. L-48 and L-82 are the same.
Old Dec 16, 2012 | 01:51 PM
preston1967
Cruising
That is an awesome diagram. It seems I have everything right. Darn front intake is just too high. The hood stops about 4 inches from closing. Its probably something stupid but for the life of me I am frustrated. So the radiators and everything are the same..geesh. Any ideas?
Old Dec 16, 2012 | 05:21 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Do you have the front duct under the radiator support? Putting it across the top of the whole front assembly will mess up the hood closing for sure. It slips in between the radiator and brace across the top.
Old Dec 16, 2012 | 06:01 PM
briankeery's Avatar
briankeery
Caseys response make a lot of sense......4 inches seems like something up front is binding.
Old Dec 16, 2012 | 08:00 PM
preston1967
Cruising
OK..man do I feel dumb. Ran out and with a little pushing it went right in..hood closes perfectly! You guys are awesome...owe beers
Old Dec 16, 2012 | 08:05 PM
texasbaehr's Avatar
texasbaehr
Check your ground on the door locks. The system is grounded in one door only. I had to replace the ground wire and add another ground on the opposite door to get both to work.
Old Dec 16, 2012 | 08:06 PM
preston1967
Cruising
Its been a 3 month fight but that concludes all the mechanicals!!! Start it up and head for California..it will get there. Now If I can just get everything else to work. You guys have any ideas on that door lock?
Old Dec 16, 2012 | 08:18 PM
preston1967
Cruising
That...I have not done. Will try it tomorrow. Thanks
Old Dec 17, 2012 | 09:20 AM
Easy Mike's Avatar
Easy Mike
...That is an awesome diagram...
The diagram is a page from the 1980 assembly instruction manual (AIM). Order the AIM; they're worth the cost and handy to have around.
Old Dec 17, 2012 | 12:24 PM
texasbaehr's Avatar
texasbaehr
The ground is in the RH door. Here is a link to a thread with the wiring diagram.
http://forums.corvetteforum.com/c3-t...wont-lock.html
Old Dec 17, 2012 | 04:45 PM
briankeery's Avatar
briankeery
Do you happen to have a library of every AIM ever produced.....LOL!!!!
To 1980 door lock problems/intake problems
