ethanol effects on fuel pumps
Yes, your concerns about the fuel pumps are valid.
Here is some info from the product manager of fuel systems for Carter fuel pumps from just last year, 2011.
You can take his word as gospel.
It should go without saying, Federal Mogul didn’t revise their fuel pumps in the last several years for a non-existent problem.
Pontiac Carter pumps are the same internally as Chevy and other GM, available in the crimped oem style, if looks are important.
http://www.highperformancepontiac.co...s/viewall.html
Note the text:
As low-level ethanol-blend fuel grew more common over the years, Federal-Mogul revised its fuel pump internals..........."
The 'grew common' the author refers to was in the 80's and 90's, not yesterday as you've assumed. E10 has been available across much of US and Canada for several decades, more than 30 years in the Pacific NW originally called 'gasohol'. How come failures of fuel pumps are unknown in these areas despite the high concentration of vintage vehicles?
On the bright side!
Merry Christmas, Hope you all get new vette parts
Nuff said-
Just because you haven't personally experienced the negative effects of ethanol doesn't mean the problem doesn't exist.
If ethanol is a non-issue, why should we care if it's 10%, 20% or 50%?
Ethanol is nasty stuff and the higher the concentration, the bigger the issues become in older cars.
You don't hear much about it in new cars because this issue has been engineered out of their systems over time.
Modern fuel injection systems are relatively immune since the pumps, lines/rails and injectors have very little, if any rubber parts and those parts are now made out of Viton or Nitrile.
Avoid going to gas station that do not pump a lot of gas, the ethonol in the gas stations tank will attract moisure if it sits for along time.
I bought a boat in the US about 3 years ago and chased a miss and poor performance for about a year. I changed the usual, spark plugs, filters, assortment of electical components, etc. One day I decide to siffon out some of the gas from the bottom of the tank. I pulled out 1 1/2 gallons of water. Once I completely emptied the tank and replaced the gas the boat ran like new.
Its easy to test. Let the car or boat site for a day. siffon out enough gas to fill a clear glass. let it sit in the glass for about 1/2 hours to an hour. If there is water it will settle on the bottom. Gas is lighter then water. The water will always sit at the bottom of your tank. As you drive the water mixes with the gas and gives you poor performance.
No amount of stabilizer will elimintate the water. Stabilizers can not turn water into fuel. If they could our fuel crisis would be solved.
J
Here is a report from the Oak Ridge National Labrotory - the U.S. Department of Energy’s research lab.
http://www.ornl.itp.govtools.us/docu...l%20Report.pdf
Can you give us an outside report backing your point of view?
What happens on your boats, lawn mower or open cans of gas don't really apply to C3 Corvettes that have sealed fuel systems.
You guys can shout 'the sky is falling' all you want, please carry on.
Has nobody thought to mention to the OP that his symptoms of no start sound nothing like a bad fuel pump?
Years does not mean decades.
Let the spinning contiunue....
