Roller Cam Swap
Will be starting a roller cam swap & head gasket change soon and wanted to get all my procedures down before starting.Questions I have are as follows:
1) What if any pre-assembly lube do I need for the roller lifters,cam lobes.This is a billet core from Crane Cams # 119821
2) Will be using a Cloyes 9-221 timing cover with adjustable cam button.How can I adjust for correct cam play with the engine in the car?
3) Will degree cam,any benefits of installing cam advanced? or just install straight up per specs? I think this cam is ground 4deg advanced already..Any way to tell if that is the case?
4) Have a Crane distributor with adjustable collar.Tips on setting up the correct cam gear lash?
5) Will check for correct valve train geometry,lifter manufacture recommends 7.100 length pushrods with Edelbrock Aluminum Heads.Sounds about right??
6) Changing out head gasket to a Fel Pro 1094 .015 thickness to increase c/r and better quench.Any gasket sealer? Copper coat spray??
7) Sealer for new head bolts? Apply to all bolts??
8) Type oil and weight for use with roller cam?? Mobil 1 ok?
Thanks for the assistance ....
2. Snug button to 0 play then back off to .005 endplay. Can check with a dial indicator or a feeler guage anywhere you can with the intake off.
3. Install sraight up. Look at your cam card. You will have an ICL and an LSA. They are likely 4 apart. This is your ground in advance and most are 4 degrees.
4. http://www.precisionenginetech.com/t...upport-part-2/
5. Always check before ordering pushrods. Never trust anything other than actual, hands on checking with a pushrod checker.
6. I have used these numerous times dry install without issue.
7. You will get a variety of answers. I use this http://www.ebay.com/itm/PERMATEX-IND...e_Lots&vxp=mtr
8. OH OH!
Amsoil Z-rod 10W-30 is hard to beat, I know it is a roller. I use Amsoil 10W-40 AMO in my roller 383
From the cam card you will see the .050 valve event numbers. When the Intake opens........................ your numbers are 0 34 E 48 -6 http://www.cranecams.com/68-71.pdf
now online look at an equivolent Comp Cams and look at the valve event numbers. Generally in the past Cran cams are not ground with any advance. CC are ground 4 degrees advance.
Only use sealer on bolts needing it. The TQ value needed changes with what is on the treads.
I have the Moroso tool to measure the needed dizzy height.
I would use higher zinc oil and probably around 10w-30
Timing set has a bronze thrust washer,cam gear looks to be machined for use with that thrust washer.What was the issue with the Cloyes cover?
Summit carb has been working great since install.EZ to tune,comes with a DVD explaining how to tune it.It's a nice running street carb & fuel mileage has also increased. Thanks...
Timing set has a bronze thrust washer,cam gear looks to be machined for use with that trust washer.What was the issue with the Cloyes cover?
So I had to take the cover back off and machine the front of the cover down for clearance.
That is when I got to talking to the race motor shop about my screwed up Cloyes operation and they told me that good timing sets don't need a button stop anyway. So I have never assembled an engine again with some phoney button stop.
Just think about it for a minute. If the double roller chain is so ridged that it is even hard to get the chain and gear on. Why would the cam ever come forward?
another question which direction does the dizzy gear to cam gear cause thrust?
I put lube on the lifter bodies, cam lobes and roller wheels. Also on dist gear and pushrod ends and fule pump pushrod. (You may need a different dist gear and fuel pump rod for your billet cam)
What I did..assemble the cam and timing chain,with the cam button installed and the cam pushed forward as far as it will go. Put the timing cover on gently so that it keeps contact with the timing button. Remove the timing cover and put a dial indicator on the cam. Set ot at 0, then push the cam back into the block. Should be between .005 and .010. If not, adjust the cam button.
3) Will degree cam,any benefits of installing cam advanced? or just install straight up per specs? I think this cam is ground 4deg advanced already..Any way to tell if that is the case? No.
4) Have a Crane distributor with adjustable collar.Tips on setting up the correct cam gear lash? Cant help.
I used .5 shorter and they were pretty close. You wont know for sure until you mock it up and measure. Too many variables like deck height, head gasket t hickness rocker arms etc..
No. Just bare is fine as long as your deck is very smooth and clean.
I used thread sealer on all of the head bolts. Only blind tapped holes dont require it.
Any regular motor oil is fine. ALthough i used cam break in additive when i started up just for extra safety. But roller cams dont require it.
Cloyes cover may interfere with your short waterpump. You may need a spacer or extra gaskets....and then your pulleys may be off....
another question which direction does the dizzy gear to cam gear cause thrust?So I guess that the cam can walk forward and cause issue's.Hope that Cloyes cover doesn't cause any problems.Will post up progress when the swap starts in a week or so.
This article had to have a phoney stretched out chain to loose 12 degrees of timing. About the only good point was aligning the crank gear with a straight edge to the cam gear. Allot of motor building is paying attention to details
When You assemble the short block with the timing chain. I've put a large screw driver down a lifter bore and tried to pry on the side of a cam lobe to see how far the cam could move front and back. With a good timing set you can't hardly move the cam.
Never checked for pushrod length with a hyd lifter before.Covering all the bases before I open the engine up....Thanks
Ralph
