Hi 1,
With the engine and shielding in place very little can be seen of the harness and clips.
You REALLY need the AIM to see where the clips are and how the harness was routed. It was low on the firewall, ran just under the wiper motor.
Again, 71, and quite different than your 69.
Regards,
Alan
Hi 1,
The AIM is your friend.
Here's the horn relay position on my 71.... I believe it's in the same place on your 69.
Regards,
Alan
Hello Alan 71
Just wanted to let you know that I noticed your wiring and attention to detail. I am restoring a 1969 BB and have to wire and run vacuum lines,would you have any more pics of "REDS" engine compartment. Thanks Mark Richardson
My car is a '69 BB, non-A/C. Here are some pictures of the engine compartment right after the engine was re-installed. Sorry if the wiring and vacuum hoses are not hooked up, but they are in their proper locations.
super nice photos, looks like top flight status.
I am putting together a 69 BB non A/C car 427(CE-Block) and hoping I could use yours as a standard!!
I would like to post some pics but when I try to insert image it wants a URL ?
I have close to the limit of 100 photos in my albums. Never used photo bucket or anything on-line.
Go to User CP, Pictures and Albums. Create an album. Upload your pictures from wherever you have them. Select (left click) the picture you want. Look below the picture. There are two links. URL and BB Code. Copy (right click) the BB Code link and paste it wherever you want in your post. Do the same with any other pictures from your album.
