trw mono spring
Old Dec 19, 2012 | 11:47 AM
shineysideup's Avatar
shineysideup
Default trw mono spring
I know there is several threads on here concerning the TRW mono spring. I put mine on when I was doing the frame off restoration without doing enough research, anyway i've since put the body on and am almost complete with the assembly. My question is will this thing settle very much? I contacted corvette central where I purchased the thing and they said they get this question a lot and the spring will settle after about 100 or so miles. Well i'm about 4" too high and I doubt it will settle that much. Has anyone had any luck with them settling down? I bought the lowest weight rating in hopes of getting the best ride.
Old Dec 19, 2012 | 12:09 PM
MelWff's Avatar
MelWff
Are you using the 8" spring bolts?
Old Dec 19, 2012 | 12:52 PM
shineysideup
yes
Old Dec 19, 2012 | 01:49 PM
MelWff's Avatar
MelWff
Are the nuts close to the bottom of the thread on the bolt?
Old Dec 19, 2012 | 02:01 PM
SteveG75's Avatar
SteveG75
I ended up with 10" (C-4) bolts on my TRW spring. Very close to rubbing on my 255/60R15 tires. For my rebuild this past year, I wanted a stiffer spring so I got a custom one from VB&P. 400# rate, shortened 1/2" per a side. Works great and no extra cost or time.
Old Dec 19, 2012 | 03:21 PM
shineysideup
The nuts are backed off as far as possible. I just put new wheels tires on 225/45/18 and now it looks even higher. My ride height is 10.5 inches measured from the rocker in front of the rear wheel
Old Dec 19, 2012 | 04:56 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
4X4 Vette!
Maybe not.
Old Dec 19, 2012 | 05:15 PM
7T1vette's Avatar
7T1vette
It should settle down some more. If you selected the 360# spring, it will ride high (about 2" over stock position). With 8" bolts, you have done all you can do with that spring, I think.
Old Dec 20, 2012 | 09:46 AM
oldalaskaman's Avatar
oldalaskaman
op might post pic's, his measurements of ride height from the rocker?
Old Dec 20, 2012 | 12:09 PM
pauldana's Avatar
pauldana
it will never ever settle... I also have the TRW... and yes a mistake... 10" bolts are the only fix... and yes, spring needs to be at least 1/2" shorter on both sides, i had to grind mine...
Old Jan 10, 2013 | 04:54 PM
CorvetteCentral.com's Avatar
CorvetteCentral.com
Platinum Supporting Vendor
The TRW mono spring will settle with regular driving over time. Here are the published ride height specs for C2 & C3 Corvettes: http://tech.corvettecentral.com/2011...-height-guide/
To trw mono spring
