no vacuum advance?
Old Dec 20, 2012 | 09:07 PM
tgcattle's Avatar
tgcattle
Default no vacuum advance?
hey guys long time no see. I have gm's 350/290 hp crate engine. In the specs it says not to run any vacuum advance. I recurved my dist. to be all in by 36 deg. I did not hook up vacuum advance because the distructions said not to. This is contrary to what I was always told. Others who have this engine say they get 20mpg. i get 10mpg. Would vacuum advace help my mpg? Why does GM say not to use the vacuum advance? If i do use it, timed or manifold vacuum, I was thinking manifold pressure. I have a performer manifold, edelbrock 750, headers. Also a 2300-2600 stall. After the holidays i am going to intall some
64cc 2.02 heads ported and polished cast iron (cuz i am poor) and a new cam. I was thinking a 284H-10
Duration at 050 inch Lift:240 int./246 exh. Valve Lift with Factory Rocker Arm Ratio:
0.507 int./0.510 exh.
Lobe Separation (degrees):110
Should I use the vacuum advace with the new upgrades?
What do yall think of this cam?
Thanks Again
Terry
Old Dec 20, 2012 | 09:25 PM
drwet's Avatar
drwet
I can't imagine why GM would suggest not running vacuum advance. I suspect you misinterpreted the instructions.
That 350/290 engine used GM's 3896962 camshaft which is an excellent street cam, in spite of the fact its getting a little dated. Its probably not worth changing it. Your money would be better spent elsewhere, especially if you can't afford really good heads.
And yes, hooking up the vacuum advance will improve your mileage substantially!
Old Dec 20, 2012 | 09:47 PM
68thumper's Avatar
68thumper
Use manifold vac...check timing at with it connected at 3,000 with a timing light to be sure timing is around 50 degrees give or take...adjust idle speed because the additional timing will most likely increase the idel speed...IMHO
Old Dec 20, 2012 | 09:54 PM
tgcattle's Avatar
tgcattle
Distruction clearly state.... Set spark timing at 32deg @ 3000rpm with with vacuum line from dist. removed and plugged. says this will produce 32 deg of total timing at WOT and the vacuum cannister should remain disconnected. This engine is designed to operate using only the interal centrifugal advance to acheive the correct timing curve
Old Dec 20, 2012 | 10:13 PM
68thumper's Avatar
68thumper
Best timing will most likely be between 32 and 36 depending on a bunch of variables...try it at 32 then go to 34 then 36. As for the instructions saying to keep the vac. disconnected I don't understand why. The purpose of the vac. advance is to provide more time for a lean burn at cruise assuming of coarse that your carb is set up correctly for better fuel mileage.
Old Dec 20, 2012 | 11:09 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
That's the part I'm not buying. I have yet to see an engine/cylinder design where the combustion burn rate was independent of the load (ie: pressure) in the cylinder.
Old Dec 20, 2012 | 11:11 PM
7T1vette's Avatar
7T1vette
It's a small block V8. Is it an HEI distributor? Does it have the timing curve built into it already? If you have a standard distributor with a vacuum can, I say "Bunk!" on the 'instructions'.
To check it out, just put a timing light on it at idle with vacuum can disconnected and plugged. If it reads something in the 12-18 degree BTDC range, your timing system is not going to work well. It needs to be in the mid-20's somewhere....which is what it would do with the vacuum advance active.
Now, if for some reason it reads something in the mid-20 degree range with vacuum can disconnected and plugged...something else is going on that none of us know about.
Old Dec 21, 2012 | 12:08 AM
tgcattle's Avatar
tgcattle
I have the timing all in at 3000rpm...36deg no vacuum connected. Runs strong, gas mileage sucks though. I don"t understnd why the instructions say that. After the holidays I will hook up vacuum advace and see what happens. I wonder if the other guys who have this motor hooked up the vacuum advance?
Old Dec 21, 2012 | 12:10 AM
tgcattle's Avatar
tgcattle
yeah HEI dist. intial timing was around 12 i think
Old Dec 21, 2012 | 12:24 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Hook the VA to manifold vacuum. Check it @ steady 3000 RPM. If your @ 54 or under your good. Fuel mileage will increase to over 16 with better cruise. Will likely need to adjust idle speed and mixture. Less advance runs hotter, meets emissions easier, less chance for detonation or engine damage so warrantee claims reduced.
Old Dec 21, 2012 | 12:34 AM
68thumper's Avatar
68thumper
Old Dec 21, 2012 | 01:00 AM
Ironcross's Avatar
Ironcross
Performance engines don't need a VC can....Most distributors have 12 degrees built in...double that its 24, and if you put 12 on the crank your total will be 36...I don't know why this story comes up every few months about a VC can....One more time for the record, FI cars did not have them either and a proper tune can give 18-20 miles per gallon at highway speeds and better... and with stiff gears....Lousy gas mileage means the combination is suffering badly from its components and/or choice of parts....
Old Dec 21, 2012 | 01:38 AM
scottyp99's Avatar
scottyp99
I believe those modern FI cars have a way of measuring engine load and advancing or retarding timing to compensate for it. It's true, having a functional vacuum advance unit will not increase your engine's performance. It is there to increase fuel mileage and idle quality. Not running any form of vacuum advance on a non-computer controlled engine is strictly for guys who like to brag about what crappy fuel mileage their car gets.
Scott
Old Dec 21, 2012 | 07:00 AM
scottw's Avatar
scottw
This is what the instructions say for my ZZ4.
"Set spark timing at 32º before top dead center (BTDC) at 4000 RPM with the vacuum advance line to the distributor
disconnected and plugged. This setting will produce 32º of total advance at wide open throttle (WOT). The HEI
vacuum advance canister should remain disconnected. This engine is designed to operate using only the internal
centrifugal advance to achieve the correct timing curve."
I have it hooked up and it runs great. With it unplugged, 32 degrees at 2800. Plug it in and I'm at 52. Not sure why it says to keep it unplugged but that is what GM crate engines call for.
Old Dec 21, 2012 | 11:15 AM
63mako's Avatar
63mako
I do! Same reason they had crappy curves to begin with. Emissions and warrantee
Old Dec 21, 2012 | 11:33 AM
69427's Avatar
69427
Originally Posted by Ironcross
Performance engines don't need a VC can....Nonsense Most distributors have 12 degrees built in...double that its 24, and if you put 12 on the crank your total will be 36...I don't know why this story comes up every few months about a VC can....One more time for the record, FI cars did not have them either and a proper tune can give 18-20 miles per gallon at highway speeds and better... and with stiff gears....Lousy gas mileage means the combination is suffering badly from its components and/or choice of parts....
Every modern performance engine has the electrical/digital equivalent to vacuum advance. The common MAP sensor is standard in almost every GM vehicle for the last 30 years. This MAP sensor measures the manifold vacuum and allows the ECM to modify the spark timing over differing load levels to optimize fuel economy, cooling, and engine durability. It's a waste of a good engine to increase the cylinder wear by flushing in excess fuel (and air) to deliver the same power that could have been delivered with less fuel if proper timing had been utilized.
As I mentioned before, I have yet to see a cylinder head design that enables a combustion burn rate independent of the pressure in that cylinder.
Old Dec 21, 2012 | 11:41 AM
63mako's Avatar
63mako
I know you have forgotten more than many know on here but this is one of those things you forgot that is actually important. Vacuum advance is needed on a street engine if you want decent fuel mileage period. If your running full throttle down the dragstrip no problem not having it. Just because a select few american built 12 to 1 V8 engines that ran on 100+ octane were produced in the 60's without it has no bearing on it's necessity on a 9 to 1 mild street engine in 2012.
To no vacuum advance?
Old Dec 21, 2012 | 03:44 PM
diehrd's Avatar
diehrd
I think the directions are accurate and the people reading them are messed up .
It is not saying never to use the vac advance it is saying to SET TIMING .. Come on now read it and re read it ... SET TIMING if you got that part NOW realize all our distributors only use centrifugal to achieve total advance and achieve the correct curve. Thats because we all know under wot throttle the vac advance totally drops out of any function affecting timing advance. Matter of fact the instant vacuum drops the advance is pulled off from functioning .
I am wondering if this whole topic was designed to be a play on words to spur a pointless discussion
Lastly the vac adv , its main reason to exist is for steady cruse and idle , where fuel can go un-burned and cause pollution ,the vac adv compensates for this by creating a spark earlier in the pistons travel to TDC making sure the flame front gets a chance to burn the most amount of fuel present. Can this cause better mpg I have never looked at it that way and thus have no idea but I guess ya sure it might help...
Old Dec 21, 2012 | 07:00 PM
olescarb's Avatar
olescarb
The reason GM instructs you not to use the vacuum advance is because it supplys too much advance for the engine, it is a 20 degree advance unit. Delco sold a d1370a vac advance that had 10 degrees but it is NLA but they are still avalible thru amazon.com or Standard Hygrade sells one.
I hope this helps Henry @ olescarb
Old Dec 21, 2012 | 08:37 PM
Ironcross's Avatar
Ironcross
Scott
You must have interpreted my post incorrectly....the FI cars {my own} received the mileage I referred to, was my 61 and 62...., not the modern whatever's and done with a 4.1 and 4.56 gears...Some may have thought I was against a VC can......not so if I misled you....Its important on most ofl the non performance engines used by the membership....However I agree a 290 HP modern engine is not a performance engine, at least not to me and maybe a few others here....
maybe I could use that little 290 HP thingie to start my 'BIG' ones though....
