From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
HOW Much Ping Is TOO Much?
I recently finished installing my newly rebuilt distributor back into my '77. When I tried to time it I discovered my damper had moved and was rubbing against the timing cover. After installing the new damper I wanted to time my newly recurved distributor for all in 36 degrees advanced before 3000 RPM. The initial timing ended up at 12*BTDC and the car runs, and starts great,the throttle response is better then ever! IF I lug it down to 1500-1800rpm in 4th gear and floor it on a slight hill I can "induce" just the slightest bit of detonation. Of course you would never do this in normal driving! and the car had left over 87 octane in it! I have been told by some very sharp old time hot-rodders that if I have to work that hard to make it ping that it's probably setup perfect. I want to try the same test w/ some 93 octane or 89 but the winter weather is not cooperating. What do you think??
Early detonation can be very damaging to the engine; so you don't want it to ever happen. I would recommend that you back the distributor down a degree or two to eliminate it altogether.
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
I wouldn't sweat it. Light knock isn't that harmful. It's undesirable of course, but it generally doesn't cause damage. If anyone recalls the 2.5 liter four cylinder found in millions of GM fwd cars in the eighties, that engine was knocking every time the throttle was opened. Because it came in the low cost vehicles, most (if not all) of the engines didn't come with electronic spark control (ESC). The engine ran on its programmed timing curve no matter what.
Knock isn't an indication of a correct or incorrect timing curve (only a dyno or cylinder pressure sensor can tell you), but from your comments on how well the car is running, it sounds like you're pretty close to what the engine wants.
I would set it one or two degrees less, run the old gas out and retime it when you are running better gas. If it still pings at 12, go down 1 or 2. Why pay the money of a rebuilt motor just to set the timing too high and have detonation damage? JMO.
if you have to work that hard to get a rattle its not that big of a deal.
If its annoying, change one advance spring for the next heavier spring or back it down until it stops
It does not rattle under any kind of normal driving condition, you have to setup conditions to "induce" it to rattle! I can easily use up the 87 octane w/ out rattle. The problem is winter weather is knocking at the door and the car is semi put away for winter!
Dump a few gallons of VP's C12 race fuel (108 octane, leaded) in there. Smells great when you run the car in the garage...with the door open, of course. If I were you, I would not have any ethanol fuel in my tank for winter storage, regardless of what Mike Ward thinks. He doesn't have a single penny invested in my car. Can't you run it near empty, then go find some non-ethanol "Recreation 90" fuel somehwere...like where boaters go?
Advancing the distributor until the engine pings under heavy load is probably the best way to maximize performance. A number is just a number and is only used for a point of reference. Conditions change and so does that number. Unfortunately I can't hear the death rattle in my car because the pipes are way too loud and my hearing ain't what it used to be. I really don't lug the engine, nor do I wind the **** out of it until the valves float..
BTW, how old does one have to be to be called an old timer anyway?
The term "old timer" is relative but I think he only needs to be at least 10 years older then the listener! I am a Commercial Pilot and my cars and bike are stored in hangers for the winter where 100 octane low lead avgas is available and they will all get some before January !
Being an "Old Timer" I will tell you what we would do to set the timing if the mark on the pully was off or there was no light available .
Bump the timing ahead untill we could make it ping and back it off untill the ping was gone . Lots of times back in the late 60s - early 70s when we did a tune up and set the timing to spec the engine would ping . We would back it off untill the ping was gone and hope it didn't hesitate after .
Originally Posted by Ironcross
You have already been told, ither put better fuel in it or drop the timing a taste......a solution ither way
The OP said it rarely knocks, and only when put in purposely unusual conditions. Higher octane fuel would be a waste of money at every fillup, and backing off the timing would be a waste of fuel and performance every time the car was driven.
Thanks for actually READING my post, I think a few guys don't comprehend the fact that I could easily drive this car a thousand miles and never have it ping unless I did something that I would never normally do and neither would anyone else ! I had a 35 year top pro mechanic drive the car and he said is does not ping! Regardless, I am thankful and appreciative to all who take the time to answer w/ their opinions and I read all, CAREFULLY !
My car is set up like yours and I use it to find out who's selling crap gas . If I fill up and I get pinging then I know not to go back to that station. One time it was so bad I called weights and measures from the state to go down and check the guys pumps because my car rattled so bad I had to buy a bottle of octane boost!
