A/T Transmission lines
Old Dec 26, 2012 | 04:56 PM
Roco71's Avatar
Roco71
Default A/T Transmission lines
My car is a 71 350 with th400 I was about to order new Transmission cooler lines and I see that there are two offered. One for a "long" fuel pump and one for a "Short" fuel pump. This is the first the I heard of two different fuel pumps for a A/T. My fuel pump does have the return line does that make it a long pump?
Old Dec 26, 2012 | 06:08 PM
Peterbuilt's Avatar
Peterbuilt
Default What?
That's an odd question, what does the fuel pump have to do with the transmission lines?
Old Dec 26, 2012 | 06:09 PM
TimAT's Avatar
TimAT
Old Dec 26, 2012 | 06:22 PM
Roco71's Avatar
Roco71
Originally Posted by TimAT
I do not have OEM Lines on my car now so I am not sure. Do the lines run under the fuel pump? There are two offered from more that one vendor and even Summit list two for the same size engine and one for a short and one for a long.
Old Dec 26, 2012 | 06:32 PM
Roco71's Avatar
Roco71
Here is an example I suppose I should ask the vendor.
http://www.zip-corvette.com/ProductDetails/ProductDetails.aspx?pid={60c476d7-53e8-4f97-97c7-132f2662fd73}&gid={3a73f3a0-0b0a-4620-b0a8-bb064f7e68b7}&GroupName=Transmission+Coo ler&pname=70-74+454+%26+70-76+350++Auto+Transmission+Cooling+Lines& Referer=&Alias=&ptct=SGR-SR&CTitle=&
http://www.zip-corvette.com/ProductDetails/ProductDetails.aspx?pid={5b61312c-d39e-4e55-9f00-9d3908f60f25}&gid={3a73f3a0-0b0a-4620-b0a8-bb064f7e68b7}&GroupName=Transmission+Coo ler&pname=68-69+All+%26+70-79+350+Auto+Transmission+Cooling+Lines&R eferer=&Alias=&ptct=SGR-SR&CTitle=&
Old Dec 26, 2012 | 06:43 PM
Mooser's Avatar
Mooser
Here's the BB with the long pump
SB would be back farther I guess. Not sure what a short pump looks like as far as the lines go
HIH
Mooser
Old Dec 26, 2012 | 07:02 PM
Peterbuilt's Avatar
Peterbuilt
Default Just learned there is a difference...
602=short [ump
603=long
Read "item description" at the bottom of the ad.
Old Dec 26, 2012 | 07:03 PM
Peterbuilt's Avatar
Peterbuilt
602=short pump
603=long
Old Dec 26, 2012 | 08:58 PM
Roco71's Avatar
Roco71
HIH
Mooser
My fuel pump looks like yours I guess that is the long canister. I am thinking that the short canister does not have the return line. The part that puzzles me is that the fuel pumps without the return line are LT-1 and they are all manual trans. I must be missing something.
To A/T Transmission lines
