#s matching motor question
Old Jan 3, 2013 | 10:48 AM
VetteNURSE's Avatar
VetteNURSE
Default #s matching motor question
I am having my sbc rebuilt and upgraded in my 76, car has 90k miles on it. Just heard from the motor guy, he claims it is a new motor due to the fact that it is so clean, no ridge what ever on the cylanders and the cylanders are round and true, stock bore. said it might be an old GM target motor. the big question is how do I tell if it is a re stamp because the number does match??? Stamp pad does look like others I have seen on the forum.
Old Jan 3, 2013 | 11:01 AM
Mike Ward's Avatar
Mike Ward
Your 'motor' guy doesn't know how to read a pad? Post a pic.
Old Jan 3, 2013 | 11:03 AM
AirborneSilva's Avatar
AirborneSilva
There should be a cast date code on the side of the block.
Old Jan 3, 2013 | 11:09 AM
MrJlr's Avatar
MrJlr
Old Jan 3, 2013 | 11:22 AM
VetteNURSE's Avatar
VetteNURSE
Mike you may have misunderstood my question. The pad is not in question, it matches my car. According to him the condition of the motor is too new to have the 90k that is on my odometer.
Old Jan 3, 2013 | 11:35 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by VetteNURSE
...The pad is not in question, it matches my car...
The pad can be in question if your mechanic is correct. You are going to need the casting date and casting number from he block to get to the bottom of it. You could also get the casting number and dates from the heads and intake manifold while you're there.
Any reason to believe the engine is not original?
Old Jan 3, 2013 | 12:18 PM
VetteNURSE's Avatar
VetteNURSE
Thanks easy mike, No reason to think not original...untill now!
Old Jan 3, 2013 | 12:45 PM
VetteNURSE's Avatar
VetteNURSE
OK just got another update from the hot rod shop. The date code does match the car! yay! So evidently the block has been bored .020 so that explains the way it looks, so it is matching numbers. Its about all a 76 L48 can have going for it.
Thanks for the info,
Mike
Old Jan 3, 2013 | 02:31 PM
Easy Mike's Avatar
Easy Mike
Thank your mechanic for shooting your blood pressure through the roof over the possibility of a restamp.
Was he playing Gotcha?
Old Jan 3, 2013 | 03:38 PM
Mike Ward's Avatar
Mike Ward
stock bore.
Not only can he not read a pad, he apparently can't measure very well either.
Old Jan 3, 2013 | 04:18 PM
VetteNURSE's Avatar
VetteNURSE
Thanks Ward for making me feel even better!!!
Old Jan 3, 2013 | 08:51 PM
scottyp99's Avatar
scottyp99
I'd find a new engine guy.
Scott
Old Jan 3, 2013 | 09:41 PM
MrJlr's Avatar
MrJlr
Lol....but Mike is a smart guy .....I'd listen....
Old Jan 3, 2013 | 09:58 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Sounds like it was recently bored .020 over and rebuilt. If there is no ridge, bore dimensions are good and cylinders are round why are you rebuilding it?
To #s matching motor question
