Frame
Old Jan 4, 2013 | 08:12 AM
Cobfree's Avatar
Cobfree
Default Frame
I have a matching number 1968 that is a grreat 10' car. The front frame was bent some years ago and I would like to correct. The question is should I buy a complete frame or cut off and weld on just the front from the windshield forward to retain the matching number frame?
Old Jan 4, 2013 | 08:19 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
How badly bent is the frame? They can be straightened unless it is very badly damaged.
Old Jan 4, 2013 | 08:37 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Define "bent" frame. How badly bent since you say the car otherwise looks fine.
Do you have alignment isses?
Old Jan 4, 2013 | 09:34 AM
Fast81's Avatar
Fast81
PM me if you're looking for a frame
Old Jan 4, 2013 | 09:36 AM
Cobfree's Avatar
Cobfree
I have had it at two shops and they both think the frame cannot be made straight on a rack.
Old Jan 4, 2013 | 09:38 AM
Cobfree's Avatar
Cobfree
Also have alot of shims correcting the alignment.
Old Jan 4, 2013 | 10:23 AM
SuperBuickGuy's Avatar
SuperBuickGuy
cut the numbers off the new frame and weld your numbers onto it? that'd be pretty easy to do.
Generally speaking, when a frame is hit hard enough to be un-straightenable the damage goes to the rear bumper. In addition, the frame ends up in a parallelogram shape (rather than square), and, because everything on the frame is tied together, it'll move the opposite side rail as well.
Most frame shops, when they pull a frame back after damage, are looking to get the suspension mounting points to where they belong or where it can be aligned - they don't care (because to make it perfect, if possible, would increase the time involved exponentially - and most people freak at the additional cost).... thus, if it got hit hard enough to move a suspension mounting point, you can be certain that there's other non-factory bends in the frame. (to be clear, this is NOT an indictment of frame shops - they do what the customer wants, the car to drive as well post-accident as it did before.)
Old Jan 4, 2013 | 10:25 AM
Cobfree's Avatar
Cobfree
Good thought
Old Jan 4, 2013 | 10:38 AM
capevettes's Avatar
capevettes
CF Community Team
2016 C2 of Year
IMO if the frame cannot be straightened and is beyond repair you need a new frame. The numbers on the frame are so difficult to see with the body on I think any attempt to cut/weld your old numbers on the new frame would draw more attention to the repair than necessary.
Old Jan 4, 2013 | 10:44 AM
Cobfree's Avatar
Cobfree
I need to price it both ways. I think replacement is the best way to go
Old Jan 4, 2013 | 01:07 PM
SuperBuickGuy
pretty much any qualified welder can weld and finish the numbers back onto the frame in a manner that only an x-ray of the site would reveal what happened. That said, I'd keep the cut-off numbers as part of the document history of the car to remain beyond reproach
Old Jan 4, 2013 | 01:24 PM
Cobfree's Avatar
Cobfree
I thought it would add value to have the frame numbers match. But dont want to spend more maintaining than the value.
Old Jan 4, 2013 | 02:00 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by Cobfree
...I have had it at two shops and they both think the frame cannot be made straight on a rack...
That's more than bent. That's bent all to H*ll.
Originally Posted by SuperBuickGuy
...cut the numbers off the new frame...
Check with the DMV first. Cutting and welding numbers could be illegal.
...I thought it would add value to have the frame numbers match...
Not really. One of the numbers cannot be seen with the body on the frame. The second number is sometimes visible but it takes a concerted effort to find it and actually be able to read it.
Old Jan 4, 2013 | 02:09 PM
Cobfree's Avatar
Cobfree
You folks are making the decision easy... thanks
Old Jan 4, 2013 | 08:41 PM
LT-1 kid's Avatar
LT-1 kid
I agree with mike, it is very hard to see any #s on most frames.
Old Jan 4, 2013 | 08:44 PM
loup68's Avatar
loup68
Army
Most original 68 frames do not have the extra kick-up channels that were added for strength,I think in very late 68's and 69- up frames. I highly recommend getting a frame with the removable transmission cross member, for a 4-speed. It sure makes life easier! Lou.
Old Jan 4, 2013 | 08:47 PM
tommy1727's Avatar
tommy1727
Do not section the frame. If it can't be repaired, replace it!
Old Jan 4, 2013 | 08:49 PM
SuperBuickGuy
Let me guess, the tags ("IT IS AGAINST FEDERAL LAW TO REMOVE THIS TAG") are still attached to your chairs, mattress and easy chair?
It's a crime to alter the VIN in the commission of a crime. Therefore, if you're not committing a crime, it's not illegal. What's not illegal is legal. I get to explain this often - there's a thing called a moral law, which could apply in this case; but moral law and US law don't live in the zip code.... one guides behavior, the other punishes criminals - but for you to be a criminal you must break the law.
clear as mud?
Old Jan 4, 2013 | 09:12 PM
Manuel Azevedo's Avatar
Manuel Azevedo
If your frame is that bad replace it! But trying to add your frame numbers to another frame is the same as re stamping an engine block!!!!!!!! THAT IS NOT THE ORIGINAL FRAME!!!!!
To Frame
