I currently have a 400 with a set of 492 heads. I am looking at a set of 215cc Dart Pro 1 heads. They have 72cc chambers. My block is 30 over with a comp 268 cam. 3.75" stroke using 5.7" rods. Speed Pro Hyper flat top pistons. If I am doing my math correct even with the 72cc chamber I would still be at 10.0:1 compression. Looking for opinions on the these heads working with my set up. Will match the heads with a RPM Air Gap intake. What say you gear heads?
i dont have much knowledge on the 400sbc's but i do know they have a simeese bore block, which means your heads must have steam passages bored in them between the combustion chambers. if you dont have these ive herd the block will be more prone to cracking. thats just all hear say tho, no real experience.
As already stated, those heads will be a huge improvement. However, the cam you've selected won't even come close to utilizing the flow capabilities of those heads. Depending on your performance goals, you may want to go with more cam or select heads that are a better match to the 268 cam. Good luck.
how big are the chambers on the current head? Are you satisfied with the throttle response in the 2500-3000rpm range? What is the cranking compression? Any detonation problems? If the cranking comp is in the neighborhood of 185-195 use the same size chambers on your new head. based on the cam I suspect you dont turn the 400 over 6000rpm. the 215s are a little large. The afr 195 is a very versatile head, outstanding balance of velocity vs flow. The 195 would be my pick. The smallest intake port that will get the job done will give the best all around performance. Chamber size depends on how well the current chamber size is working for you. The modern aluminum head with a more efficient camber design will let you get away with a little more cyl psi (compression) and a little less timing.
Heads will be a big improvement but as said that cam is going to not allow full potential of the heads. While the heads are off put in a cam worthy of that motor and heads.
I have those heads and the rpm air gap intake.it would make great torque with that cam ,aluminum heads can handle 1/2 point more compression because they dissipate heat faster.figure out your dynamic compression to see if you can run that cam.check out comps cam quest 6 .
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I made 550Hp and 510Tq with 215cc Vic Jr heads that were actually 220cc on a 406ci solid roller engine, you need a bigger cam, these are racing pieces that you want to run on the street and it is easy to do with the correct parts, that's why they came up with cams known as "street rollers"
I am looking at a set of 215cc Dart Pro 1 heads. They have 72cc chambers. My block is 30 Will match the heads with a RPM Air Gap intake. What say you gear heads?
What is the port size of a 215 head? The rpm is:Port exit dimensions: 1.14" x 1.95".
Dart will sell 215 heads with the larger 2.08/1.625 valves. The valve size determines the max port flow. That is why AFR 195 upped the valves sizes to 2.08
Dart has a great customer service; I forwarded my questions to them and they quickly responded. Pro 1 has great chambers--the plug can't get much higher in the chamber. They also have a 5 angle cut on the intake. These are 2.05 that come on their 180s (62cc chamber) for my 355.
