T56 Experts..Please step In
Now that I have the C5 with that trans it seems that changing out the TH400 behind the 383 for the M6 will make her quite the new experience. I hope this isnt too winded but Im in analysis mode. I appreciate any info you can help out with! TIA!
T56 Years and Models - I know that the early versions (93-97) were different but not sure in what way. Some have Borg Warner tags. Should I avoid them? or are they ok. I have my eye on a rebuilt unit from this era. I also have seen different references like "viper" and "magnum". What is the significance of these if any?
Gear Ratios - Are they all the same in all units? I currently have 3.73 diff but also have a full 3.08 pumpkin I can put in. Any advice here?
Clutch - I'm thinking of going hydraulic here with a tilton MC although I have not done a lot of research here. Any info on clutch options would be great. If I decide to go with a Z bar do I need special bell housing, clutch fork etc?? I also need to get a pedal set. Is it ok to find OEM on fleabay or is there aftermarket set that would work better with hydraulic setup.?
Offset Shifter - Who makes the best?
Cross Member and Mount - Same
Anyone every use this kit?
http://americanpowertrain.com/i-8521...-corvette.html
again sorry for the winded post. Thanks for the help! Happy New Year!
I used an LT1 F body T56 with the LTx bellhousing slave etc
Used a centerforce 700107 (pretty sure)FW and dual friction clutch setup. This mates the fw to a 2 pc rear main seal and the LTx clutch setup.
Power est around 550+- holds it just fine (and I use drag radials full time), not grabby chattery etc.
Real happy with it so far. The hydraulic clutch spoils you but the bracket and geometry HAS to be right. Keisler can fill you in. I had to make mine and went through 5 slaves lol before I got it right this was around late 90s before there were parts for doing this.
On specifics with Vette installation maybe others can pipe in put this in an A body. Best upgrade ever.
PP bolts are McLeod #1502 I belive. Dont use regular bolts on them. They make a nice bolt in scattershield, too with a block plate.
http://forums.corvetteforum.com/c3-t...gs-list-7.html
If you have the money do the Viper kit. I had a low budget, so I went with a used trans and tried to keep costs down somewhat.
The unit I'm looking at is a 97 rebuilt from Camaro complete with bellhousing. I'm going to keep looking at what else is out there.
Guessing they make a bolt in slave bracket and show you where to mount the rod on your pedal. I cant think of any downside really.
Some like the retrofit kit where they can use the old style clutch and keep their linkage old bellhousing etc. Check into it.
And ditto on the 5 spd.
6th is useable if you have a torquey/mild motor....big huge cam you need deep gears in the rear and go 75+ to use it. 5 speeds are plenty, BUT nice to have the extra. I run a 4.11 and 26 in tire...6th is nice to have.
T56 has a 2.66 first which is perfect if you can find a 5 spd with the same or similart gearing no more than 2.88 go for it.
The ones with the 3.xx first gear then a huge drop to 2nd not for me.
To all, I have considered a TKO 600 but it seems I can do a T56 for considerably less $$ as they are readily available. I will do final budget compare but for some reason the reason the thought of the 6 spd with that clutch setup appeals to me. ...nothing like top end!
That said, I had to put a smaller diameter vacuum booster on my car because it was an interference fit with the clutch master cylinder. In the end I used an ebay "hot rod" dual diaphragm booster and a wilwood 5/8" bore - NOT the short one - master cylinder with a remote fill
pm me if you want the link to that part of my build.
I'd also avoid the 3.08 gear.... at .50 double overdrive 1200 rpm would be 70 or 80 mph (so pretty much useless). Also, the first gear on the GTO transmission is designed for 3.42 gears. I ran a 3.91 in my GTO, made 1st useless.... were I to do it again (the GTO was a POS and is someone else's problem now) I'd run 4.11s or 3.42s....
As for the setup:
Use the LT1 stuff, master, slave, bellhousing. You will need to extend the hydralic line but you can find adapter fittings to go from the GM oring to -4 line. Mouning the master cylinder requires a little fab work but the rod will reach the stock vette clutch pedal pin and yeilds a very short smooth pedal movement.
If you have any fab skills and a welder you can make a cross-member pretty easy.
The shifter is a little interesting. I made my own stick and used the B&M ripper shifter.
For a clutch I called Dave at Spec Clutch. I've tried Mcloed, CenterForce, Zoom, etc in my camaros and non of them compare to Spec in quality. I used the stage 2 disc and pressure plate. I also opted for the aluminum flywheel. they will custom drill a flywheel to your setup so if you have the 2-pc seal crank they will just drill a blank with the correct pattern. Need to match the balance of your current flex plate send it to them and they will make sure its the same.
You will need to change your driveshaft as the t56 uses the th350/small gm trans yoke versus the large th400 yoke. Driveshafts Unlimited in Arnold MO can set you up if your looking for a quality driveshaft shop.
Here's a link to pics of the rebuild and other various things I did to install the t56 in my vette.
t56 rebuild and install photos
Sounds like I'll be sticking with the 3.73. Should have a great launch and still lots of top end.
442olds, lots of good points here, and much obliged for the link. I was all ready to order centerforce but will check out the spec stuff. my motor is internally balanced so no issues there. Shifter I'm going to take my time on. I do have the means to fab some stuff but will most likely just go with aftermarket crossmember from US powertrain or somewhere. The trans I am looking at is a rebuild that comes with the camaro bellhousing. I wasn't planning to open it up. should I consider buying a cheaper used unit and get a trans expert to crack it open and replace the parts you mention? Im sure i can find someone local to do that. Thanks guys Im building my parts list. Will post it this weekend!
I had a 350 with a 250@050 solid roller would pull 6th...the 383 with a 260@050 pulls it even better go figure BUT you do have to be going 75ish (due to the cam). I run M/T full time and havent broken it yet. I did lose a 2nd gear pin probably from the trans sitting for 10 yrs thats it.
$5 part and a few hun labor back on the road.
http://www.chevelles.com/forums/show...2&highlight=56
http://s989.beta.photobucket.com/use...70774634019767
Now I've rebuilt two t56's, a t5 (mustang), and an NV4500 (1ton chevy truck). For whatever reason the bearing set I put in my last t56 had an issue. It was the last bearing that supports the output shaft in the tail housing. Apparently there was something wrong with the rollers and it caused all sorts of havoc. Make sure you buy quality bearings. And even then that's apparently not a guarantee anymore.
Back to clutches. I had a centerforce Dual Friction in my camaro. The clutch would expand as it got hot, it would not disengage going into 1st or reverse. And was a pain to get it into gears at the track when it was under a heavy load. The camaro boards were lit up over these dang things and eventually Ceterforce started screening calls. If you mentioned a camaro or t56 they would put you on permanent hold. Its a good clutch and a lot of people have had good luck with them, but I personally like the customer service and quality I get from Spec.
A link to quality parts, Do not get the KOYO bearings, spend the extra cash for the timken's I learned the hard way even though the guy on the phone said they prefer the Koyo's.
The Gear Box
I like the service at D&D better however.
D&D Performance
Would like to learn to rebuild these....have 2 T56 here. I trust no shop.
I had a 2nd gear pin go loose...took it in and told them to use hylomar on the case....of course they used cheap orange silicone and after 2 mos it leaks of course. As they say---
The Gear Box
D&D Performance
