NO Dash lights
Old Jan 6, 2013 | 11:54 AM
chippy126's Avatar
chippy126
Cruising
Default NO Dash lights
Team,
My 79 C3 has no dash lighs. I got it this way and have replaced the light switch and still no luck.The 7.5 fuse in the fuse block is good. Has anyone else fought this issue?
Any help would be appreciated.
Chip
Old Jan 6, 2013 | 12:02 PM
2box's Avatar
2box
I had the same problem when I got my 79 and by elimination I found the problem. Fuse, headlight switch, ground or printed circuit board. Good luck finding Your ghost
Old Jan 6, 2013 | 12:07 PM
chippy126's Avatar
chippy126
Cruising
Where is the ground? That's what I'm looking for today.
Old Jan 6, 2013 | 12:44 PM
7T1vette's Avatar
7T1vette
[This post assumes that you've turned the headlamp switch **** both directions, to make sure the dash lights weren't just turned OFF.]
Regardless of where the ground is supposed to be, you can easily test whether 'grounding' is the problem with your lights, or not. Just find a piece of wire [3' long, or more) and strip the insulation off the ends. Touch, or connect, one end to a known good ground source (metal piece connected to frame, ground lug at the fuse block, etc).
With the ignition turned to ON [engine OFF] and headlight switch pulled ON to the parking lights position, touch the other end of the ground wire to some metal components on the backside of the driver's dash (speedo housing, tach housing, etc.). If grounding is your problem, the lights in the speedo/tach area should light.
P.S. Since those dash lights draw a fair amount of current, there may be some sparks when you make ground connection. But, there is no risk of getting shocked or causing a fire (unless there is a mouse nest of fibers right where you are making the connection ). It is always a good idea to remove any rings or metal jewelery to prevent any possible direct short through them.
Old Jan 6, 2013 | 01:06 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
The ground is on the left hinge piller above the courtesy light.
http://corvetteforum.net/c3/tunedpor.../index23.shtml
Old Jan 6, 2013 | 11:11 PM
desue's Avatar
desue
LOL, I have a similar issue, I have dash lights SOME of the time, and when I do, they are very dim. Best of luck to ya!
To NO Dash lights
