Chasis work about to get interesting
as some of you may know, I'm doing a body off resto-mod on my '81 coupe, in between getting the new engine sorted out and off to the machine shop, I've been working on stripping the frame down to parade rest to send in and have it blasted and powder coated. I'm sending the frame, trailing arms, upper and lower control arms, sway bar, coil spings, radiator support and drive shaft for coating, the shop quoted me $400.00 for everything.
anyway, it will be there about a week so I have time to order some parts for putting it back together, I'm replacing all the brake lines, hoses, fuel lines, calipers, rotors, bushings(all of them), ball joints, tie rod ends and the like.
my question is, which type of bushing should I use? this won't be a track/race car, just a nice weekend cruiser. I've heard the urethane are better for performance but the rubber offer a more comfortable ride. is this true?
also, does anyone know of a good quality "KIT" that has all the bushings for my car in one package? I can "piece" it all together but thought it would be easier to just order one package.
also, has anyone been able to talk to the vendors and swing a discount because of ordering large $$$'s of parts at the same time. (just a thought).
thanks in advance.
I've used poly before and it's more expensive and I don't think they last as long as people claim. I put poly motor mounts in 2 years ago and the drivers side is all melted after 6k miles. Going to replace this with rubber this year.
thanks in advance.
The only thing I might mount in poly is the front sway bar. Use washers on the frame bracket mounts so that the bushings are not clamping the bar too tight. Zero clearance but no compression.
Make sure you leave the rubber bushings slightly loose until the car is back on it's tires and the suspension has fully settled. Then torque them up. A PITA to reach under the car, but this way, it puts the bushings in the center of their travel when the car is at normal ride height.
If you tighten them up when the car is in the air and the suspension is at full droop,the bushings will not last very long.
