strut rods
Old Jan 9, 2013 | 08:09 AM
jmatt82's Avatar
jmatt82
Default strut rods
Upon finishing this winters rear suspension rebuild, I noticed one of my strut rods didnt have the same offset as the other one. I was able to get it in place, but am curious as to whether this may make it much harder on the bushing. Any help appreciated.
Old Jan 9, 2013 | 08:27 AM
bpassmore's Avatar
bpassmore
They will fit only one way, inside / outside. front side and back side. Hold the problem strut up to the mount location and fit it. Raising the trailing arm a bit helps in the alignment. Do the outside first, then diff side. The aluminum diffs all have the offset strut.
I marked mine after having the same trouble you are having.
Old Jan 9, 2013 | 08:37 AM
jmatt82's Avatar
jmatt82
My two strut rods are actually different. It must have been a replacement by the previous owner. One is more or less straight and the other has the noticable offset. Im not confused as to how they go in but rather if the straight one will damage the bushing prematurely.
Old Jan 9, 2013 | 08:39 AM
Street Rat's Avatar
Street Rat
They should both be offset. At least on my 81 they are.
Old Jan 9, 2013 | 01:14 PM
bpassmore's Avatar
bpassmore
Install struts with outboard end angled forward, easier if trailing arm is lifted level.
My '82 are offset and angled forward made of aluminum.
Old Jan 9, 2013 | 08:27 PM
Sayfoo's Avatar
Sayfoo
I believe on my 69, that they are both streight and symetrical.
Old Jan 9, 2013 | 08:36 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
I think the offset ones came about with the batwing and aluminum housing in 1980 and continued through '82. I bought a set of adjustables last year for my eventual rear suspension rebuild (finally in progress) in my '80. Apparently, alignment guys or bad luck with tire changers bent the two on my car and both on the spare rear suspension setup I bought probably to compensate for wear or bad bushings. I bought new, heavy duty, adjustable ones with the correct offset.
Old Jan 10, 2013 | 08:31 AM
Street Rat's Avatar
Street Rat
I checked the Eckler's website. There are three different part numbers depending on your year model. It looks as though the pre 80 models are straight. The 80-82 models appear to be offset.
Old Jan 10, 2013 | 02:14 PM
jmatt82's Avatar
jmatt82
Thats correct. Time to pull that straight one out and get one thats offset. Thanks everyone.
To strut rods
