Internal Header / side pipe coating?
Old Jan 9, 2013 | 03:42 PM
CAMS69's Avatar
CAMS69
Default Internal Header / side pipe coating?
Eastwood sells an internal exhaust coating. http://www.eastwood.com/ew-hi-temp-i...ension-tu.html
i wonder if anyone has used it and the results? I have OBX sidepipes
on my 69 and don't really want a shield, does anyone think this could cut down the temp so the hunnies (and me) wont burn their leg? Thanks!!
Old Jan 9, 2013 | 06:31 PM
7t9l82's Avatar
7t9l82
i would bt you will still burn your leg, but i plan to use it. i would run some laquer thinner thru it to clean it up first
Old Jan 10, 2013 | 01:44 AM
Learning_Curve's Avatar
Learning_Curve
I have the same setup. I'm planning on making my own inserts from some auger style inserts I bought. They are made for 3.5 inch pipe. My plans are to weld the inserts into a length of exhaust pipe, and use a layer of exhaust wrap over it before slipping them into the side tubes. I don't know how much this will help, but I had the drag pipes on my Harley wrapped and I could touch them after a long cruise without injury.
To Internal Header / side pipe coating?
