What side off the engine lifts under torque
Old Jan 11, 2013 | 08:46 PM
gve's Avatar
gve
Default What side off the engine lifts under torque
I'm trying to fit some headers on a BB and have some tight clearances to the frame, I think the left side raises with torque but I want to be sure.
Thanks, Gary
Old Jan 11, 2013 | 08:48 PM
C6DuffMan's Avatar
C6DuffMan
Drivers side.
Old Jan 11, 2013 | 08:49 PM
7T1vette's Avatar
7T1vette
If you are concerned about excessive engine movement, install some 'solid' engine mounts.
Old Jan 11, 2013 | 09:06 PM
gve's Avatar
gve
Thanks, I have mounts with the T metal that limits how much it can lift. If I use a solid mount on the drivers side and rubber on the other side would I still have some reduction of engine vibration or would it all transmit through the solid mount?
Old Jan 11, 2013 | 11:33 PM
7T1vette's Avatar
7T1vette
I think that harder 'poly' mounts are available that limit motion but still dampen some of the vibration. Just depends on what your needs are.
Google is your friend....
Old Jan 12, 2013 | 08:09 AM
daanbc's Avatar
daanbc
St. Jude Donor '12
I have a solid on the drivers side only. You don't feel anything.
Old Jan 12, 2013 | 11:00 AM
mikem350's Avatar
mikem350
When I installed my BB Hedmans Hedders I made sure to ding (flatten) the tube closest to the steering box. Shoot for about 1/4 inch gap. Lots of header installs require this.
Old Jan 12, 2013 | 11:12 AM
gve's Avatar
gve
That's the headers that have, I may have to do that I only have about a 1/8" gap there. On the right side headers they hit the inside of the frame rail and the collector is to far to the right I may send them back and have them send me another set.
Old Jan 12, 2013 | 11:36 AM
mikem350's Avatar
mikem350
Yes they are tight on the pass side too. I stuck a baseball bat inside the collector and bent them inward a little. Not easy!! Already had 'em Jet Coated...
Not sure if there are other brands to choose from...not a lot of space in there!!
Header wrap is your friend
Old Jan 12, 2013 | 12:49 PM
Rebelrob's Avatar
Rebelrob
had to ding my tube to clear the steering box. Driver side is torque side, I use energy suspension poly mounts. Work great so far.
Old Jan 12, 2013 | 07:50 PM
OzzyTom's Avatar
OzzyTom
I have a solid engine mount on left side only.
A slight increase in vibration only evident on cold start idle over standard rubber mounts.
But then again, the whole car tends to shake, rattle and roll at idle ...
No more "soiled underwear" from jammed open throttle due to broken engine mount
Old Jan 12, 2013 | 09:40 PM
DRIVESHAFT's Avatar
DRIVESHAFT
I'm not sure what heads you have, but I bet you've got raised exhaust ports.
When I was running factory oval port heads my Hedmans fit perfect.
When I started using the AFRs with the .300" higher exhaust ports, I had to ding tubes for the steering box and the right frame rail.
I doubt you'll get away with no tube dinging if your running heads with a non-factory port location..
Old Jan 12, 2013 | 10:33 PM
Rebelrob's Avatar
Rebelrob
Correct....
Old Jan 13, 2013 | 08:57 AM
Indiancreek's Avatar
Indiancreek
Used to do it on a street strip Chevelle years ago by using a small piece of chain and a turn buckle. Ran it from a front head bolt hole to a hole in the frame. It still had the cushion of the rubber mount yet limited the torque of the engine from lifting away from the mount.
Old Jan 13, 2013 | 12:04 PM
bpassmore's Avatar
bpassmore
This brings back memories, In about '71 Chevy had a recall to modify all V-8 engine mounts back to I believe '65. The rubber used in the side mounts would deteriorate to the point of separation this allowed the engine to rise up on the left side during acceleration causing the accelerator to hang, to the point that the brakes sometimes would not be very effective. GM's fix::to install a cable from the engine to the frame to limit the travel. The next year all mounts used the "T" trap in the mount.
I installed countless "Kits" on those Chevys, effective, yes, "bubba engineering", yes, but cheap and effective.
To What side off the engine lifts under torque
