1980 auto. trans. shifter options
Old Jan 11, 2013 | 10:19 PM
LWT's Avatar
LWT
Default 1980 auto. trans. shifter options
I'm looking for aftermarket automatic shifter options for a 1980 Vette using the stock console. Any words of wisdom?
Old Jan 12, 2013 | 08:26 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Keep using the stock shifter. No shopping to do and no changes to make.
Old Jan 12, 2013 | 10:00 AM
Matt Gruber's Avatar
Matt Gruber
like mike says,
and recalibrate the governor for sports car shifts. B&M kit $30 does the trick.
Old Jan 12, 2013 | 11:20 AM
LWT's Avatar
LWT
I'm going to be running a reverse pattern T-400 & I want to run a ratchet shifter. I haven't taken the console apart, but I don't think it will be too bad getting an aftermarket shifter under there & looking decent. It just made sense to ask for input from someone who had already done one. I can't be the first guy to put a shifter in a C3!!
Old Jan 12, 2013 | 11:27 AM
Street Rat's Avatar
Street Rat
The B&M Megashifter seems to be the choice of most guys here wanting a ratchet shifter. I've been searching some threads here on the same topic. It seems the model for the late 70's to early 80's Camaro is the one that fits the best with the factory console. Expect to do some minor modifications to make it fit correctly. Please post pictures if you decide to take it on.
Old Jan 12, 2013 | 11:31 AM
LWT's Avatar
LWT
Will do. Thanks.
Old Jan 12, 2013 | 02:30 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Here is a Megashifter that I installed in my car.
It's a Camaro console model. I swapped the T handle for a ball, and got a leather shift boot made for it.
The shifter handle is still a bit tall for my taste, but overall I'm pretty happy with it.
Old Jan 12, 2013 | 04:09 PM
qwank's Avatar
qwank
If you want a cool/fun shifter, the best thing to install is a manual transmission
Old Jan 12, 2013 | 04:11 PM
JimmyS5600's Avatar
JimmyS5600
Active Streak: 90 Days
Driveshaft your set up looks very nice,great job.
Old Jan 12, 2013 | 04:18 PM
qwank's Avatar
qwank
where did you get that shift ****?
Old Jan 12, 2013 | 05:39 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Thank you
http://www.hotrodshiftknob.com/
Old Jan 12, 2013 | 07:57 PM
LWT's Avatar
LWT
Driveshaft: What had to be done to make it work? Looks great, thanks for the pic.
Old Jan 12, 2013 | 08:56 PM
DRIVESHAFT's Avatar
DRIVESHAFT
I didn't take any pictures while I was doing mine, but here are a couple of links to threads that were helpful to me.
They have some good pictures that show you what needs to be done.
http://forums.corvetteforum.com/c3-t...r-install.html
I had to put it together quite a few times, while checking for clearance and then re-cutting the body of the shifter until everything cleared.
Once I could shift through all of the gears without the top console plate moving, I put it all back together.
Then it was up to my local upholstery shop to figure out how to make a shifter boot to fit.
Old Jan 12, 2013 | 09:18 PM
LWT's Avatar
LWT
Fantastic! Thanks for the links, huge help. I did a search before I posted this and didn't find anything?? Oh well, thanks again.
Old Jan 13, 2013 | 11:37 AM
Street Rat's Avatar
Street Rat
Thanks for the links DRIVESHAFT. I hadn't seen those yet.
Old Jan 23, 2013 | 03:36 PM
donnie1956's Avatar
donnie1956
I am in the process of installing the B&M quicksilver in my 78. Getting ready to cut a slot in the tunnel to lower it about 1 1/2 or so. Direct link
Old Jan 23, 2013 | 08:03 PM
LWT's Avatar
LWT
donnie1956, Sounds great. I'd like to take a look.
To 1980 auto. trans. shifter options
Old Jan 23, 2013 | 10:51 PM
donnie1956's Avatar
donnie1956
Going to cut a slot in the tunnel and drop the entire shifter down around 1 1/2 to 2 inches. Then my console will fit correctly.
Will take a few pictures once I get the slot cut. For the mount I am going to have a flat plate with the mounting holes and use a piece of square tubing to make the spacer the correct depth.
Old Jan 24, 2013 | 10:45 AM
LWT's Avatar
LWT
Great, I look forward to seeing it!
Old Jan 24, 2013 | 04:21 PM
tyancey00's Avatar
tyancey00
Hummmmm,,,, Me too!!
