No Hood Clearance
Old Jan 12, 2013 | 09:38 PM
JohnnyStingray's Avatar
JohnnyStingray
Default No Hood Clearance
Hello All...new user here. I have a 71 that i just added Hooker Headers to and was installing an Edelbrock Performer intake with my rebuilt q-jet. I did my research on here first and everyone was saying there should be no clearance issues with the performer and q-jet. But i cant even close the hood WITHOUT an air cleaner. the airhorn even hits the hood. I mean these things can only go on one way so i dont know what i could have done wrong but something is up. I had the engine rebuilt years ago...could the motor mounts be different somehow? I am at a loss. Any and all help would be much appreciated.
Old Jan 12, 2013 | 09:52 PM
Mooser's Avatar
Mooser
There are a couple of different "performer" intakes, which one do you have?
(I'm pretty sure at least the RPM ones are very tall compared to stock)
Mooser
Old Jan 12, 2013 | 09:54 PM
langg's Avatar
langg
Big block or small block?
Old Jan 12, 2013 | 09:58 PM
Mooser's Avatar
Mooser
Good point, not much of anything fits the BB, except maybe those ancient Torker II's
Old Jan 12, 2013 | 10:56 PM
Doug1's Avatar
Doug1
Originally Posted by Rebelrob
could be a matter of your air filter assembly. Do you have a drop base or stock set up? Get yourself a L88 drop base air filter set up. Should give you an extra 2 inches.
he said he can't close his hood, even without an air cleaner...ouch.
Old Jan 12, 2013 | 11:18 PM
drwet's Avatar
drwet
There ARE two different motor mounts for small blocks. A tall and a short. I have no idea if its possible to install the tall mounts in a Corvette.
Old Jan 12, 2013 | 11:23 PM
JohnnyStingray
its a regular 2101 performer...i went and got a drop base air cleaner with a thinner filter and shaved some off of the stud and i think i am in business.
thanks fellas
Old Jan 12, 2013 | 11:30 PM
JohnnyStingray
will i need to make any adjustments to the carb with this new intake?
Old Jan 13, 2013 | 03:07 AM
Scottd's Avatar
Scottd
DO NOT drop your hood to shut it anymore.....I 'clayed' my clearance after a carb spacer install. (modeling clay between air cleaner and hood, squished down to show exactly how much room you actually have) Had just under 1/4 space. One day I was having fits with the car and just dropped the hood down.......yep, you guessed it. I spider webbed my hood. Be careful with your new reduced clearance.
As far as adjusting your stock q-jet....no, adjustments are not necessary to get it to run, but they will optimize performance. You may run a little lean though.
To No Hood Clearance
