Need HELP - Engine Troubles after oil pan removal
Old Jan 14, 2013 | 08:34 PM
GorillaBaseball's Avatar
GorillaBaseball
Bad news, so I primed it for about 5 minutes until the drill battery became low. Had the valve cover off and not a drop of oil. Underneath I go...
Old Jan 14, 2013 | 08:36 PM
AirborneSilva's Avatar
AirborneSilva
that sucks, how long did you run the engine? Hopefully you didn't hurt anything.
Old Jan 14, 2013 | 08:44 PM
GorillaBaseball
I didn't run it. I didn't see any oil coming out of the rocker arms so I figured I wasn't getting anywhere.
Old Jan 14, 2013 | 08:47 PM
AirborneSilva
You ran it before, when you noticed the knock.
Old Jan 14, 2013 | 08:49 PM
GorillaBaseball
Sorry, correct. Ran it long enough to freak out and shut it down. 10 seconds tops
Old Jan 14, 2013 | 08:58 PM
AirborneSilva
Hopefully you didn't score any bearings then. You might want to think about pulling a couple bearing caps just to have a look while you're down there.
Old Jan 14, 2013 | 10:29 PM
sly vette's Avatar
sly vette
Yeah....Start with the rear main. You know...The one you removed to change the rear seal...
Old Jan 14, 2013 | 10:57 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Wonder if the pick-up simply fell off.
Old Jan 14, 2013 | 11:39 PM
noonie's Avatar
noonie
Pull the pan and check the pump drive rod and a couple rod bearings.
when you prime the oil pump, you will notice quite a bit of drag on the drill when you get oil pressure.
Here are the instructions from GM for priming the base 290 replacement engines.
The engine should be primed with oil prior to starting. Follow the instructions enclosed with the tool. To prime the engine, first remove the distributor to allow access to the oil pump drive shaft. Note the position of the distributor before removal. Install the oil priming tool, GM part number 12368084. Using a 1/2" dill motor, rotate the engine oil priming tool clockwise for three minutes. While you are priming the engine, have someone else rotate the crankshaft clockwise to supply oil throughout the engine and to all the bearing surfaces before the engine is initially started. This is the sure way to get oil to the bearings before you start the engine for the first time. Also, prime the engine if it sits for extended periods of time. Reinstall the distributor in the same orientation as it was removed.
Old Jan 15, 2013 | 10:08 PM
GorillaBaseball
Wanted to give an update. Tonight I dropped the pan and on the surface everything looked fine. Took out the pump and noticed some crud in the pick-up. Gave it a tap on the floor and you would be amazed at what fell out. I am firmly convinced it was blocked. Bought a new pump and waiting for the pick-up to come in. Should of replaced the pump the first time....
Old Jan 15, 2013 | 10:40 PM
bluedawg's Avatar
bluedawg
Hopefully that solves youre problem.
Old Jan 16, 2013 | 02:27 AM
7T1vette's Avatar
7T1vette
Good find. BTW, a cordless drill will NOT provide the power necessary to pump oil up and through the engine. Just pull the center distributor wire off and crank the engine till oil pressure comes up. THEN, put the dizzy wire back in and fire it up.
Old Jan 16, 2013 | 08:59 AM
  #33
Brcmpbl's Avatar
Brcmpbl
Interested in this one, best of luck luck with your problem and please do let us know how you make out with the new pump.
Old Jan 19, 2013 | 09:00 AM
  #34
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Can you tell how clean the engine is? I skimmed the thread but didn't notice if you indicated this is a rebuild or an original engine.
I noticed you filled with AMSOIL which is what caught my eye. Modern synthetics have much better detergent properties than legacy conventional oils. Though in the 10 sec that the engine ran it is not likely the AMSOIL cleaned anything. However, there might have been sludge in the pan which was sucked into the pump.
In old engines that are upgraded to modern synthetics, AMSOIL advises a flush prior to first use using this or something similar to it:
AMSOIL Engine and Transmission Flush
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Jan 20, 2013 | 12:47 AM
  #35
GorillaBaseball
This is an original engine with 87K on it. I chose Amsoil SAE 10W-40 Synthetic Premium Protection Motor Oil after reading a few threads about motor oils and older engines needing higher zinc levels that modern oils don't seem to have. If this oil is over kill, would love to know because its not cheap!
Old Jan 20, 2013 | 07:56 AM
  #36
C66 Racing's Avatar
C66 Racing
I think the oil is a good choice and many with flat tappet cams use it. I used it in my LS6 engine for several years at the track before AMSOIL released their Dominator racing oils which I now use.
The other good choice for this type of application comes in a 10w30:
AMSOIL Z-ROD 10w30 Synthetic Motor Oil (Product Code ZRTQT)
(zinc – 1440 ppm, phosphorus 1320 ppm)
With 87K its hard to say how much sludge is in the engine. If the oil was changed regularly, it shouldn't be excessive.
Good luck with the prime and if you need AMSOIL in the future, more than happy to get AMSOIL products for forum members at dealer wholesale pricing, about 25% below retail, via the AMSOIL Preferred Customer Program. Drop me a PM if interested.
Old Jan 22, 2013 | 11:38 AM
  #37
GorillaBaseball
Wanted to give a quick update. I got the pick-up screen in this weekend, replaced the pump and put the oil pan back together. Primed the pump for about 3 minutes, put the distributor back in but was having trouble with spark plug wires crumbling due to age. So replaced the plug wires and cap. Took the center cable off the cap and turned the engine over. Oil pressure went up to 40 - 50 PSI.
Went to start it and its not firing. I thought I marked the distributors position when I took it out but apparently I don't have it in the original spot. Took an attempt at finding Top Dead Center by lining the timing mark on the crank pully to the 0 degree mark on the timing chain cover. Then used the location of the distributor as #1, and re-ordered the spark plugs. Still not luck so I ordered a piston stop and did a lot of reading. I still need to figure out if I was on the compression stroke and looks like I should of set it to 8 degrees before top dead center.
Old Jan 22, 2013 | 12:30 PM
  #38
Mike Ward's Avatar
Mike Ward
You don't need to be that precise to get it running. Most likely you were at TDC on the exhaust stroke and not compression. Turn the engine 180* and try again.
