exhaust manifold threads
![](/forums/images/ranks/4k-5k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/veteran_marine_corp.png)
![](https://www.corvetteforum.com/forums/images/ranks/cf10.jpg)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Hello everyone,
I purchased an original '69 828 RH exhaust manifold.
I has been painted or treated w/ unknown coating.
I'd like to clean out the threads in the air tube mounting holes before
installing plugs. I'd also like to clean the three threaded holes with a tap first in flange area where the heat riser and down pipe are attached.
Does any one know the thread pitch or tap size I need to use for the air hole threads and the flange hole threads?
Thanks in advance.
Marshal
Thanks in advance.
Marshal
Jnb5101,
Thanks for the thread pitches.
You were spot on!
I ran a tap through all holes last night and all the threads were good.
Lucky I had the right size taps on hand.
A little rust caused some initial resistance.
I shot some kroil in there and went at it.
They cleaned up nicely.
You never know how these old manifolds were treated but this one held up well.
Marshal
You were spot on!
Marshal
