Fouled spark plugs
Old Jan 18, 2013 | 08:48 PM
TXredc3's Avatar
TXredc3
Default Fouled spark plugs
Engine is missing most likely due to a fouled spark plug. Is there an easy way to determine which cylinder is not firing?
Old Jan 18, 2013 | 08:55 PM
brady5885's Avatar
brady5885
Start the engine from stone cold and feel the temp of the primarys on the headers.
Cold or cooler one than the rest will show a cylinder not firing or intermittently firing
Old Jan 18, 2013 | 09:10 PM
Mod75's Avatar
Mod75
2024 C3 of the Year Winner - Modified
Using a temperature gun would be the easiest, the low temp would indicate the fowling cylinder.
Old Jan 18, 2013 | 09:55 PM
scrappy76's Avatar
scrappy76
You could also start the car and once it is warmed up, you could pull each plug wire off the the distributor one at a time and when the idle doesnt change, you have found the culprit. I will warn you, you might get shocked. once you find the plug, replace it and add a " no foul " to get you by till you can fix,rebuild, or replace motor.
Old Jan 18, 2013 | 10:12 PM
flyeri's Avatar
flyeri
Best idea so far
To Fouled spark plugs
