Hooker side pipes
Old Jan 19, 2013 | 11:27 PM
Hub454's Avatar
Hub454
Default Hooker side pipes
I am looking at putting hooker side pipes on my 68 but need to know if stainless or ceramic coated will look and last longer. What are your thoughts?
Old Jan 19, 2013 | 11:36 PM
Learning_Curve's Avatar
Learning_Curve
Stainless should last longer, but may need polished from time to time. The stainless will discolor, especially in the primary tubes near the engine.
You thinking Hooker brand or cheap knock-offs?
Old Jan 20, 2013 | 12:15 AM
3JsVette's Avatar
3JsVette
Polished stainless does turn yellow.
Old Jan 20, 2013 | 06:40 AM
72SLEEPER's Avatar
72SLEEPER
Obx heard good things
Old Jan 20, 2013 | 07:54 AM
540 vette's Avatar
540 vette
I had Hooker ceramic coated on my 77. Didn't discolor and looked great. It had a 540 in it. The car sounded great. But if you like to smell like gas fumes they do the job. I used to pull up next to someone and they would roll up their windows.
Old Jan 20, 2013 | 11:45 AM
commander_47's Avatar
commander_47
That is the scent of POWER
Old Jan 20, 2013 | 12:13 PM
REELAV8R's Avatar
REELAV8R
You can get the hooker headers directly from Jet Hot ceramic coated. The ceramic has the additional benefit of keeping the under hood temps down. I have a pair and the quality of the ceramic coating is excellent.
Old Jan 20, 2013 | 01:43 PM
worship79's Avatar
worship79
I'd go stainless. My ceramic flaked off (hooker factory applied!) and then rust kicked in. Wont happen to you with stainless, which also looks better imho then the ceramic coating.
Old Jan 20, 2013 | 08:08 PM
Mod75's Avatar
Mod75
2024 C3 of the Year Winner - Modified
I had the chrome Hookers on my 75 for 6 years, the Chi-Town salt started to eat up the collectors within two years, at 5 years they looked ugly.
Old Jan 20, 2013 | 08:17 PM
Batvette71's Avatar
Batvette71
get used to getting your legs burt at least once . after that you will never do it again
Old Jan 20, 2013 | 09:15 PM
Learning_Curve
Wear jeans. No grown man looks good in shorts...
Old Jan 20, 2013 | 09:51 PM
Hub454's Avatar
Hub454
Default Side pipes
Has any one tried the Obx headers? Or are the other side pipes worth looking into? I want them to look good 5 yrs from now.
Old Jan 20, 2013 | 10:00 PM
Learning_Curve
Search OBX and you'll come up with a slew of threads. I've happy with mine so far, but my car is not on the road yet. I had to take a dremel to a few of the bolt holes to get the bolts started in the heads. I would suggest lining a gasket up to them and checking BEFORE their installed.
BTW, I'm fabbing up a junkyard rack and pinion, so I can't comment on steering box clearance.
Old Jan 20, 2013 | 10:56 PM
mikey's Avatar
mikey
i bought hooker stainless and then had 'em jet hot ceramic coated inside and out. the stainless are lighter, won't rust, and the ceramic coating in/out keeps it cooler than anything else.
Old Jan 20, 2013 | 11:25 PM
slofut's Avatar
slofut
Smells better if you run aviation fuel or sunoco race octanes!
Old Jan 20, 2013 | 11:51 PM
SuperBuickGuy's Avatar
SuperBuickGuy
It depends on the muffler you use that determines if you get burned.... reversion mufflers keep the tubes cool
I had my Hookers ceramic coated locally - I've spilled enough brake fluid on them to say that it holds up great to all sorts of abuse.... plus you get the option of other colors beside black or chrome (I went with tungsten)
Old Jan 21, 2013 | 01:51 PM
aaroncorvette's Avatar
aaroncorvette
I never warn any chicks about the side pipes and they always burn themselves
..then I come to the rescue
To Hooker side pipes
