Headlights turned off
Old Jan 20, 2013 | 11:50 AM
Street Rat's Avatar
Street Rat
Default Headlights turned off
I just took a ride down to Houston. It was early when I left so I had my headlights on. The headlights went off about 20 minutes into my drive. They stayed off for about 10 minutes and came back on. The headlight doors remained open the whole time. The lights came back on and I had no problems the rest of my trip. I just replaced my headlight switch prior to my trip. Any ideas on the cause of this?
Old Jan 22, 2013 | 03:01 PM
MelWff's Avatar
MelWff
Either a bad connection or an overly sensitive circuit breaker in the headlight switch. Where was the switch made?
Old Jan 22, 2013 | 03:41 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Street Rat
...Any ideas on the cause of this?...
UFOs. They were curious about the C3.
Old Jan 22, 2013 | 06:20 PM
Street Rat's Avatar
Street Rat
It was a Lectric Limited switch purchased from Eckler's. I'm not sure where it was made. Supposedly it has a heavier circuit breaker in it according to the description.
http://www.ecklerscorvette.com/corve...1978-1983.html
Old Jan 22, 2013 | 08:00 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
At one time some bad switches were out there with faulty breakers in them, this may be your problem.
One thing to remember is it is possible to get a bad one from a good supplier too, and LL is a good supplier.
You can see the breaker in the picture below.
If you do need the switch I have plenty. http://willcoxcorvette.com/product_i...ducts_id=24359
Old Jan 22, 2013 | 08:18 PM
TOM B1's Avatar
TOM B1
I AGREE WITH THE BREAKER IN THE SWITCH, this is a known problem with all early cars and pickups, yes you can replace it with more China junk but I think the best way for a permanant fix is to add a relay in the light circiut, the relay will take the amps draw instead of the light switch. This is a very good fix for the brighter headlight bulbs that draw more amps like hologen "now old" and zeon bulbs.
Problem fixed.
Old Jan 23, 2013 | 08:20 AM
Street Rat's Avatar
Street Rat
Great input guys. Thanks.
If it does it again I'll put a relay in the circuit.
Old Jan 23, 2013 | 09:38 AM
Street Rat's Avatar
Street Rat
TOM B1 - I sent you PM
Old Jan 24, 2013 | 08:03 AM
Street Rat's Avatar
Street Rat
I'm taking TOM B1's advice and putting some relays into the headlight circuit. I found plenty of information on this modification on the internet. Thanks for pinpointing the problem guys.
Old Jan 24, 2013 | 07:44 PM
brando1118's Avatar
brando1118
Before you start into all of that......
I had the same issue. My headlights would not work on very cold nights. Additionally they would go off all together with no explanation. I was really scratching my head going around testing all grounds for existence and good contact. Then after giving up and sweating cold weather driving for about a year, I ripped out my interior for a wiring over haul and discovered my dimmer switch plug was worn out and loose. New plug from another harness and the headlights never went off without me turning them off again.
Good luck.
Old Jan 24, 2013 | 07:51 PM
Street Rat's Avatar
Street Rat
Good luck.
I will check that prior to adding the relays. That would be an easy fix. Just another trip under the dash...again.
Old Jan 24, 2013 | 09:59 PM
PeteZO6's Avatar
PeteZO6
Even with a relay in the headlight circuit, you still need a circuit breaker or fuse to protect the wiring. Using a fuse in the headlight circuit is NOT a good idea, so you still need a breaker.
Pete
Old Jan 24, 2013 | 10:03 PM
Street Rat's Avatar
Street Rat
Pete
I'll be using short sections of fusible link wiring on the battery supply side of the relays.
Old Jan 24, 2013 | 10:42 PM
'75's Avatar
'75
The problem with using a fusible link is that it's a one shot deal, when its burnt out you're in the dark. An automatic circuit breaker would be a better option.
Old Jan 25, 2013 | 07:33 AM
Street Rat's Avatar
Street Rat
I like that idea better. Thanks.
Old Jan 25, 2013 | 11:47 PM
0Willcox Corvette
Former Vendor
This thread has been interesting. I will say that I've not had any issues with the lamp switch breaker so I've never really seen a need to run a relay or fuse link. As I posted earlier, it is possible to get a bad switch from a good supplier and I think this may be the issue you have.
IMHO,
Willcox
Old Jan 26, 2013 | 10:06 AM
Street Rat's Avatar
Street Rat
I have a saying...If it's weird, unusual, or never happened to anyone it's something of mine.
Old Feb 5, 2013 | 08:06 PM
Street Rat's Avatar
Street Rat
I just finished the headlight relay modification. It works great. I'll be posting the process with pictures in a few days. Look for it.
To Headlights turned off
