watt ohms = full?
Old Jan 22, 2013 | 09:38 PM
dburgjohn's Avatar
dburgjohn
Default watt ohms = full?
I bought a new fuel gauge for my 81 to replace the OE one that danced. Installed it and discovered the gauge read full with 1/3 tank and double distance past full when actually full. The vender was nice enough to take that one back and send a new one. It does the same thing. I tested the resistor on the back of the gauge and it showed 90 ohms.
What is bad or what am I doing wrong?
Old Jan 22, 2013 | 09:45 PM
wombvette's Avatar
wombvette
Check for grounds.
Old Jan 22, 2013 | 10:04 PM
dburgjohn's Avatar
dburgjohn
Originally Posted by wombvette
Check for grounds.
cluster was sitting on work bench with just my jumper wires hooked direct to gauges
Old Jan 23, 2013 | 01:44 PM
super-bee_ski's Avatar
super-bee_ski
Black Brown Red Orange Yellow Green Blue Violet Gray Yellow
0 1 2 3 4 5 6 7 8 9
Resistor color code. 90 Ohm color coded resistor: Yellow band followed by a Black (single) band OR the print: 90
Can you get to the sending unit?
If so, place your Ohm meter leads on each terminal. Raise and lower your float arm and verify Ohm meter linear deflection.
Old Jan 23, 2013 | 02:49 PM
'75's Avatar
'75
Post #26
http://forums.corvetteforum.com/c3-t...-thread-2.html
Old Jan 23, 2013 | 04:46 PM
dburgjohn's Avatar
dburgjohn
sending unit reads correct with meter on dash plug. this is issue with fuel gauge. Willcox told me some repl units have resistor built in and to try without external resistor
Old Jan 24, 2013 | 07:35 AM
super-bee_ski
But 2 gages being bad ?
Okay..I "get-it"
New gage manufacture is adding resistance...
Good advice ...
Old Jan 24, 2013 | 09:57 AM
dburgjohn's Avatar
dburgjohn
Default Willcox is awesome
Willcox was right, resistor inside gauge means don't use external. This was not even his part and he answered my question.
I respond to that by planning to spend my future money with Willcox corvette and would encourage others to do so too.
Old Jan 24, 2013 | 10:29 AM
super-bee_ski
I'm on board with you!
Thanks for this post.
"super-bee_ski"
To watt ohms = full?
