i've been bubba'd
Old Jan 23, 2013 | 01:52 PM
littleredvettegirl's Avatar
littleredvettegirl
Default i've been bubba'd
I'm having problems getting out the inner tie rod ends out. It seems that the person that owned this car before put in outer ends in the inner positions and I can not get them out. can someone give me a little help here. just need an easy solution to this little issue.
Old Jan 23, 2013 | 01:58 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You can use a pickle fork on them.
Old Jan 23, 2013 | 02:00 PM
littleredvettegirl
anything else that i can use don't have a picklefork anymore the last idiot that was here to work on my car scooped it.
Old Jan 23, 2013 | 02:14 PM
MrJlr's Avatar
MrJlr
Pickle forks are cheap.....just get another....
Old Jan 23, 2013 | 02:21 PM
carcraze's Avatar
carcraze
Have a read here as I have always just put some pressure with a pry bar ans hit it on the side to destub the taper.
http://www.nichols.nu/tip701.htm
Old Jan 23, 2013 | 02:33 PM
Marlin's Avatar
Marlin
AZ/Advance also have forks in their loan a tool program. Also a good hit on the SIDE of the rod head will usually get it to pop out as well.
Old Jan 23, 2013 | 03:41 PM
wcsinx's Avatar
wcsinx
Pickle forks suck
Get one of these ...
http://www.summitracing.com/parts/otc-6297
and never again fight those damn joints
Old Jan 23, 2013 | 03:46 PM
MrJlr's Avatar
MrJlr
Originally Posted by wcsinx
Pickle forks suck
Sweet !
Old Jan 23, 2013 | 03:47 PM
'75's Avatar
'75
http://www.harborfreight.com/3-4-qua...tor-99849.html
Old Jan 23, 2013 | 03:52 PM
commander_47's Avatar
commander_47
Borrow one for free from auto zone.
Old Jan 23, 2013 | 04:01 PM
wcsinx's Avatar
wcsinx
sonofa...
never would've guessed HF would have them too
I paid $50 for mine.
Old Jan 23, 2013 | 04:33 PM
gkull's Avatar
gkull
The Harbor Freight tool is good for about one use
Old Jan 23, 2013 | 04:35 PM
littleredvettegirl
I got one there for 12 bucks about 3 yrs ago and it was great. I helped my hubby with his 3 rebuilds and used it on all three and it was still fine.
Old Jan 23, 2013 | 04:48 PM
wcsinx's Avatar
wcsinx
Then the reason you're trying to separate tie rod ends with a pickle fork is.........?
Old Jan 23, 2013 | 04:50 PM
littleredvettegirl
read the first entry lol. never mind i got it thanks all
Old Jan 23, 2013 | 04:52 PM
wcsinx's Avatar
wcsinx
I did. The theory is the same regardless of if you used the right parts or the wrong parts. Glad you're sorted out now.
Old Jan 23, 2013 | 07:03 PM
540 vette's Avatar
540 vette
Are you talking about getting them out of the sleeve or the centerlink.
To i've been bubba'd
Old Jan 23, 2013 | 08:41 PM
Scottd's Avatar
Scottd
Do you have an air compressor? Do you want to make this an easy job? Do you have about 75 bucks to invest in cheap tools?
1) HF pneumatic hammer gun
2) pickle-fork for above tool. (I got the craftsman combo kit for about 45 bucks)
Those joints will split in about 15 seconds. No worry about smashing your knuckles, swinging a hammer in enclosed spaces, knocking over your beer with said hammer......
Old Jan 23, 2013 | 09:43 PM
Learning_Curve's Avatar
Learning_Curve
Pickle forks suck
I borrowed this tool from work and actually managed to break the cross pin while seperating the ball joints from the control arm.
Old Jan 23, 2013 | 09:46 PM
REELAV8R's Avatar
REELAV8R
I didn't even know there was such a tool. Very cool. Looking around a little I found you can buy an entire front end service kit. Front end suspension stuff has always been problamatic due to difficult dis-assembly. this kit would make it a lot easier.
http://cgi.ebay.com/ws/eBayISAPI.dll...tchlink:top:en
