80 backfires
Old Jan 25, 2013 | 10:26 PM
jr917's Avatar
jr917
Default 80 backfires
Hello all hope all is good trying to start my 80 after new carb install she cranks turns over but she backfires and won't stay running can anyone give me some ideas thanks jr
Old Jan 26, 2013 | 08:34 AM
Matt Gruber's Avatar
Matt Gruber
try the old carb again.
Old Jan 26, 2013 | 08:42 AM
diehrd's Avatar
diehrd
depress pedel to floor and hold it there as you crank her, once it catches you will know
Old Jan 26, 2013 | 12:08 PM
jimboscarbs's Avatar
jimboscarbs
The only reason it should backfire is that it is lean...
or you are firing while and intake or exhaust valve is open.
Verify fuel supply
did you take any of the plug wires off for any reason???
if so check your plug wires
Best Regards, Jim
Old Jan 26, 2013 | 07:44 PM
jr917's Avatar
jr917
I put the old carb back on it still back fire
Old Jan 26, 2013 | 07:46 PM
jr917's Avatar
jr917
The spark wires are new all electric is new thanks
Old Jan 26, 2013 | 08:17 PM
LastC3AZ's Avatar
LastC3AZ
Where's your timing ....
if the back fire is through the carb .... its too lean ..... if out of the exhaust ... too rich
Old Jan 26, 2013 | 08:49 PM
sly vette's Avatar
sly vette
Did you change the plug wires at the same time as the carb? Sounds like you got a crossed wire or your timing is off.
How did it run before you changed the carb. What else did you do or change when you changed the carb?
Old Jan 26, 2013 | 08:57 PM
dburgjohn's Avatar
dburgjohn
double check your plug wires if you replaced them. verify #1 on the compression stroke and firing order of the other plugs. even the best of us have mixed it up. Especially if the install happened long after midnight.
Old Jan 26, 2013 | 10:09 PM
Doug1's Avatar
Doug1
I had same problem, after clearing up fuel and timing, came to conclusion that my valves were too dirty. at least I hope this was the cause, took some time this week to clean valves and port heads and intake manifold. few more things to hook up tomorrow and give rtv time to fully cure, will know for sure tomorrow. may try adjusting valves to possibly save a bigger job of having to pull the heads.
Old Jan 27, 2013 | 08:10 AM
Matt Gruber
X2 on adjusting valves.
Old Jan 27, 2013 | 08:35 PM
jr917's Avatar
jr917
Yes I changed the wires at the time I changed the carb I will try thanks
Old Jan 27, 2013 | 08:38 PM
jr917's Avatar
jr917
I changed the cap and the plugs will look into the timing and the cross wire thanks
Old Jan 29, 2013 | 05:57 PM
dburgjohn's Avatar
dburgjohn
crossed wires will mess you up. we used to switch the center two on the old in-line 6 cyl as a joke. Will start and idle, but runs like crap.
Old Jan 29, 2013 | 06:26 PM
Doug1's Avatar
Doug1
update, cleaning the valves did not fix it. next step, which I should have done when I had heads off and valves out, will be the springs. Been conversing with TimAT about my load and all the stuff I have already done. This hopefully will fix my pig.
Old Jan 29, 2013 | 11:14 PM
jimboscarbs
Default whats your pig doing???
Can you give some more information about what your hot rod is doing and we may be able to point you in the right direction...
driving beaters as a teenager has its advantages later on in life
Old Jan 30, 2013 | 08:33 AM
diehrd's Avatar
diehrd
This topic is a mess
Old Jan 30, 2013 | 07:18 PM
DaveL82's Avatar
DaveL82
HEI module failure causes same backfiring
Old Jan 30, 2013 | 08:14 PM
Doug1's Avatar
Doug1
been having backfire through the carb at higher rpm and when giving lots of gas(throttle more open to WOT), got springs done earlier tonight, gonna give a couple heat cycles before really getting on it hard. dizzy, wires, fuel pump, carb are all new. timing has been messed with every which way till sunday and cleaned up the valves and heads.
thanks.
To 80 backfires
