Pinion Nut Woes
Old Jan 28, 2013 | 08:23 PM
edk136's Avatar
edk136
Default Pinion Nut Woes
I would like to personally thank whoever changed the pinion seal last and used green loctite on the nut. This went from a 1/2 day job to... it's time to pull the rearend and of course all of the "while I'm at" jobs. With everything out of the car except for the front and rear suspension, I'm very close to the "might as well pull the body" dilemma
Old Jan 28, 2013 | 11:14 PM
TimAT's Avatar
TimAT
Green is medium strength. Be happy he didn't use red..
Old Jan 28, 2013 | 11:50 PM
edk136's Avatar
edk136
Well based on my limited research, it depends on which green loctite was used. The green retaining compound is apparently used when you want the nut basically welded on. All I know, there is a bunch of a green substance at the end of the pinion and I twisted a 1/2" extension by using a breaker bar. I also used a 3/4" air impact gun after heating it with MAPP gas to no avail.
Old Jan 29, 2013 | 12:24 AM
erikm12's Avatar
erikm12
Usually at work if we run into something with red, heat does the trick. I would think it would for green too.
Old Jan 29, 2013 | 06:42 AM
edk136's Avatar
edk136
That's what I'm hoping for. I just couldn't get it hot enough while the rearend was still in the car.
Old Jan 29, 2013 | 12:04 PM
my 76 ray's Avatar
my 76 ray
You might need an oxy/acetylene torch to get it hot enough.
Old Jan 29, 2013 | 12:50 PM
lionelhutz's Avatar
lionelhutz
If your meaning of MAPP is one of the small propane bottles with the screw on head then you need more heat. Doesn't necessarily have to be acetylene but you need a setup with an oxygen tank.
Old Jan 29, 2013 | 01:07 PM
redvetracr's Avatar
redvetracr
things could have been worse, the pinion nut could have come loose.
Old Jan 29, 2013 | 02:46 PM
edk136's Avatar
edk136
That's for sure!!!
Well I'm trying to look at the bright side of things, at least this will give me a chance to get my rearend cleaned up
To Pinion Nut Woes
