79 Coil / Dist. Replacement Recommendations
Old Jan 29, 2013 | 01:25 PM
FriscoScooterTrash's Avatar
FriscoScooterTrash
5th Gear
Default 79 Coil / Dist. Replacement Recommendations
I suspect there is trouble (intermittent starting) in my stock Accel HEI coil and / or the distributor / rotor. Any recommendations on replacements?
Old Jan 30, 2013 | 01:17 PM
MelWff's Avatar
MelWff
You dont want to diagnose what the real problem is, just replace everything? You havent even looked for a bad connection in the harness going to the distributor?
Old Jan 30, 2013 | 03:17 PM
FriscoScooterTrash
5th Gear
I disassembled and inspected the entire coil, distributor, cap, pickup coil, sending unit, mechanical / vacuum advance and all connectors and wires. Bench tested everything. All OK.
Re-assembled to continue testing, but the engine started!!! Drove it to work and home the next day, ran perfect.
The next morning the engine would not start, again. Not even a cough of combustion. The tach indicated RPM while cranking, so it is getting the timing pulses from the pickup coil / sending unit.
I think the distributor cap and rotor are probably the problem, they are the moving parts that wear out. I have a request in to Accel for the resistance readings I should have on the coil, no word from them yet.
Old Jan 30, 2013 | 03:42 PM
Mike Ward's Avatar
Mike Ward
Accel coils are not 'stock', offer no performance upgrade over GM parts are more expensive and reputedly less reliable.
Aside from that, they're great.
Old Jan 30, 2013 | 04:03 PM
MelWff's Avatar
MelWff
the resistance readings are located with the part description, i assumed you have a 140005, if not look up the correct one
http://www.summitracing.com/parts/acc-140005
Old Jan 30, 2013 | 04:15 PM
jb78L-82's Avatar
jb78L-82
I would check and or replace the distributor control module. I had mine work intermittently years ago-Would run fine and then not start on the next start cycle. Replaced the module and everything has been fine-20 years!
To 79 Coil / Dist. Replacement Recommendations
