Fuel Line on 72
Old Jan 29, 2013 | 04:15 PM
dc502's Avatar
dc502
Default Fuel Line on 72
I have a 1972 Base model stock 350, Bubba got to the fuel line and cut it about 4 inches from the Q jet and put in a rubber line with a glass inline filter. I want to get this cleaned up. I was wondering if anyone uses those braided fuel lines like the ones from Russel performance, or should I just use an OEM replacement line? If I use the braided line type, what do I need to make it work. Ill be putting the OEM replacement filter back in the Q Jet. I did search and read a bunch of posts on here but didn't find one that had the pros and cons
thanks for the help
Paul
Old Jan 29, 2013 | 04:45 PM
Alan 71's Avatar
Alan 71
Hi Paul,
The stock line is pretty straight forward. You can see it in this picture. It makes a 60 degree right turn toward the carb just where it disappears under the air cleaner.
Certainly not as spiffy looking as a braided line would be.
Regards,
Alan
Old Jan 29, 2013 | 04:53 PM
dc502's Avatar
dc502
Thanks Alan
that looks nice and clean, I may just go that route, it looks clean and I hope would just hook right up with out a bunch of adapters. Thanks for the pic.
Old Jan 29, 2013 | 05:20 PM
Alan 71's Avatar
Alan 71
Hi dc,
The one problem might be the fitting in the carb. Sometimes the threads stripped or the seat in the fitting for the flare on the fuel line distorted.
Other than that it should be pretty straight forward.
Regards,
Alan
Mashman's Avatar
Mashman
Beware, Bubba may have cut it for a reason.
You should always double wrench when working on the connection between the fuel line, and the carb fuel inlet. If you don't you can wreck both the carb inlet, and the fuel line. Bubba may not have done that, and may have wrecked both. The fuel line can twist, and the inlet threads are easily stripped.
For twisted fuel lines, Bubba likes to cut out the twisted part, and replace it with a rubber line. For the stripped inlet threads, Bubba likes to remove the internal filter, exopy the inlet into the carb, and put an external filter in the line.
So be carefull, since you have that external filter, Bubba may have epoxied the inlet into the carb.
Old Jan 29, 2013 | 05:26 PM
sfrank2886's Avatar
sfrank2886
thanks for the help
Paul
Go with the braided fuel line unless you are working on an all original motor. Much easier to work with looks good too!
Old Jan 29, 2013 | 05:27 PM
sfrank2886's Avatar
sfrank2886
Originally Posted by Alan 71
Hi Paul,
Regards,
Alan
Alan, go drive that car! It is way to clean.
Old Jan 29, 2013 | 05:34 PM
dc502's Avatar
dc502
Mashman
I was thinking that very thing. I'm planning on sending the Q Jet to Lars here real soon, I wanted to have the fuel line all ready to go when I get the carb back. I was just wanting to see what others have done, Its always nice to use someone's good ideas and not make the same bad ones. I have seen them cross threaded but not epoxied. If it can be done wrong bubba will find a way
here's hoping it was a twisted line.
thanks for the input
Paul
Old Jan 29, 2013 | 05:35 PM
dc502's Avatar
dc502
To Fuel Line on 72
