C3 Hood Prop Upgrade
I now can lift my hood with one finger, and open and close it with one hand. I have been using it on my '79 for about two years now, and it has worked perfectly. Every 'Vette guy who sees it comments about what a good idea it is. So I thought I'd post it for those of you that might want to convert their own cars.
You remove the old prop and leave the end brackets mounted to the hood and fender. Just mount the ball joints to the existing end brackets.
I used SPD Gas Springs parts from their online catalog.Here are the parts to buy:
1x GSNI-5200-60 Gas Spring, $15.84(-60=60 lbs lift, or use -75=75 lbs)10" retracted, 17" extended, .24" rod,.59" body
(They also have an all Stainless gas spring available with the same dimensions, looks really cool, but it's over $50)
2x BS-1009-SS Ball joint ends, $3.66/ea
2x NU-1200-SS Lock Nuts for ball ends, $0.25/ea
The gas spring comes with plastic ends, they'll work, but if you want SS ends(I used SS), add:
2x EF-PS90-SS Stainless Steel gas spring ends, $8.18/ea
Here is a photo of the installed Gas Spring, and two more close-ups of the ends to aid in assembly:
And close-ups of the ends:
Give it a try-you'll wonder how you ever lived without it!
The hood closes very easily. Identical to the original setup. At the point of closing, the spring's force is almost entirely applied in the horizontal. The more you open the hood, the more force becomes vertical. The hood is already applying it's full weight when it is open with the factory prop. The weight on the fender is no different with either device. The gas spring just makes opening the hood easier for the person doing it. All the gas spring does is counter most of the hood's weight. When closed the tension from the gas spring is exerted horizontal with the fender lip, that's much stronger than it's vertical weight capability. As I wrote previously, I have been using this on my car for over two years now. I have closely inspected the areas of concern both before the install and at regular intervals since, and have observed zero changes in the bodywork. The area of the fender that holds the hood prop was designed by Chevrolet to adequately support the full weight of the hood in it's raised position. Any surface features visible in my photos were there before I changed anything.
When I decided to try this installation, I measured the distance between the stock prop's mount points with the hood closed and open, to determine the length and stroke needed. I then weighed the hood through it's travel from just "popped" to fully open, to determine the minimum spring force necessary to counter most of the hood's weight. It is not an overly strong spring. The hood does not "open itself". But with the gas spring installed, it feels like the hood only weighs about 10 pounds. That's why I chose a 60 pound gas spring, and why I wrote that you could use a 75 pound if you want. There is leeway there.
To summarize - It Works Friggin Fantastic!
I Quote:" Any surface features visible in my photos were there before I changed anything."
My car wasn't perfect when I bought it 5 years ago. As close as the picture was taken, you would see irregularities all around my hood lip area. Hell, you could see the hairs on a flea's *** if you were this close. Before I installed the new gas springs, I photo logged the areas shown, and they look the same today as they did over 2 years ago.
http://cmc.speeddirect.com/items.asp?Cc=HOOD&Bc=
P.S.: Oh,man. I hope I don't get that company cheesed off at me for undercutting on their business! They may be a paid supporting vendor. I don't want the administrators to delete my postings and sock me with a bunch of "bad boy" demerits over an inadvertent violation of forum policy. You really have to be careful on this forum with spreading your ideas. The paid vendors are the darlings of the administrators. If any of them think you are hurting their business-BANG!-the hammer comes down on the insignificant little non-paying member. So, I'm Sorry to anyone who feels they have been affected negatively by my reporting of an idea I had. Please buy your hood struts from a paid forum vendor.
I highly doubt any Moderator will have a problem with what you posted
Thank you again for the info you posted.
