Carb Spacer Question
So, my question is will installing this carb spacer on the Edelbrock RPM Air Gap affect idle, performance, etc. because of the issue with the open space in the divider wall? See photos so you can see what I am talking about.
Any thoughts, suggestions, feedback would be appreciated. Thanks!
My only concern Now is the gap below the carb spacer where the notch is in the divider wall of the intake and how it might affect idle, acceleration, performance, etc...
Now his 7000# truck can accelerate from 20 mph in 5th, without downshifting!
New Book: The Horsepower User Control Panel (0 new messages) • View your posts
Search (Native)
Search (via Google)
FAQ
Members
Logout [ Matt Gruber ]
User Control Panel
Overview
Profile
Board preferences
Private messages
Usergroups
Friends & Foes
Compose message
Manage PM drafts
Inbox
Outbox
Sent messages
Rules, folders & settings
View messages: Inbox
Folder is 72% full (36 from 50 messages stored)
Reply to message
Return to Inbox
Next PM in history
Delete message
Report private message
Quote message
Re: 4165
Sent: Sun Jan 27, 2013 9:10 pm
Sent: Sun Jan 27, 2013 9:02 pm
by lee_beazley
I am rebuilding the 4165. I, just today, finally managed to get it apart. The old gaskets were glued like epoxy. Tomorrow I'll get some gasket remover and finish cleaning. I already have the kit. I think I'll just get a new 2161 Edlebrock, when I get ready.
For now, I now have the 4777 and newly filled air gap running so well, I'm going to follow that up. It'll be good to have something to compare to anyway.
It's astounding what that little filler did. The mpg might still be less than I had hoped for, up to about 10 mpg ave, still not bad for a 7000lb 4X4, but this is fun and interesting. I have the idle leaned to about 14:1 AFR on the guage. It's not the smoothest idle but it's still good, at 750 rpm. Starts with the touch of the key. The smoothest idle is rich, 13.0:1. The secondary plate is almost closed and there is very little slot expposed at idle. No hesitation though.
I went down two more primary jets to 63. The AFR, cruise at 55 to 65 mph, is now 14:5 and very steady. At 65 to 75 it leans to about 15:1. Also I see it lean for a moment when I press the gas just a little from cruise. It did this even before I changed the jets. I 'm not sure if the slot should fill this gap or if I need more pump shot. I just watch the guage and don't let it go over that. I wonder if I'm not getting enough fuel through the transition slot at the higher throttle positions. Could I need to open the idle ristrictors? I'm using the pink cam, on 3, and have gone back to the .28 nozzles. Power valve is still 8.5.
It runs great. Fast warm ups, no hesitation,
I even went through the roundabout getting on the freeway, this morning, at 20 mph, with a cup of coffee in hand, and just smootly accelerated down the on ramp to 65 in 5th gear. Unreal. Thank you again. lee
Quote Matt Gruber
4165
Sent: Sat Jan 26, 2013 12:45 pm
by Matt Gruber
lee
are u rebuilding the 4165?
maybe u can make a 4 hole adapter out of wood?
2x8" could do it. I almost made one, but not enough hood clearance.
Top
Board index
The team • Delete all board cookies • All times are UTC - 5 hours [ DST ]
Powered by phpBB® Forum Software © phpBB Group
Advertising or Affiliate Inquiries: Send PM to Forum Admin
Just to be clear, lee took 3/16" steel and drilled 4 holes in it to match the carb base. Then he welded a 1/2" piece perpendicular, in the center, to fill in the cut down divider.
You could fill the notch in with a gasoline resistant epoxy, I suppose. What's that stuff they use to help shape intake ports? That stuff should work just fine.
Scott
Scott
plus i extended it to fit under the bowls and deflect heat.
the air-gap cut down dividers, if filled in, it must be very strong, otherwise the pulses(near the speed of sound) will knock loose anything flimsey, like 1/8" aluminum
that is why lee welded 3/16" STEEL.
http://www.jegs.com/i/Edelbrock/350/8715/10002/-1
Scott
Some (spread bore) have a huge center cavity that benefit by 4 holes, but many others are fine with the 8715 style.
Scott
among other bad things
Notice how the 2601 performer air gap has the full divider? That would be the manifold to use with a 4 holer for outstanding manners.
Bottom of my Summit carb:
[IMG]
[/IMG]4 hole gasket spacer had to trim gasket to clear the Summit fuel bowl,should be fine with a Holley:
[IMG]
[/IMG]Fuel line using Fragola push on hose:
[IMG]
[/IMG
BTW, there are plenty of people who don't think that cutting the divider kills torque and some even found that it helps remove that bog in the ~2,500 RPM range.
Yes, there a lot of uninformed people that think all sorts of things. And i'd be the first to bet that there are cars out there that are so far out of tune, anything is possible.
The guys with the cut down divider had no idea at the time of purchase. Guys love the looks of the 7501, and just assume it must be better. It costs more, right? So it must be better. NOT. So far, i have not seen or read about a single engine that makes more power sucking in exhaust fumes at light throttle. Guys see dyno tests that show the 7501 makes 2 or 3 more HP at ~6300 rpm and get all excited. Not shown it the loss of 50+torque in ordinary part throttle driving.
On the topic of the cut in the divider, why would Edelbrock have spent hugh amounts of money on developing the RPM Air Gap and then go through the additional step of making the cut in the divider if it was detrimental to making power? If I remember correctly the Chevrolet book Chevrolet Power had a modification described in their intake maniold section of the book where they added the same type of cut to an intake to increase power. Not trying to argue with what others have done to fill it in, just wanted an explanation of why Edelbrock put it there in the first place.
http://www.gmtechbooks.com/sitemap/p...4502488-83.htm
