Cleaning Muncie M22
Old Feb 6, 2013 | 10:49 AM
Raider74's Avatar
Raider74
Default Cleaning Muncie M22
Hey everyone, my body off is proceeding nicely, rear ends back on the ground on its own tires. New composite spring, shocks, bushings, por-15, etc. etc... the works.
Getting to the middle of the frame here, although I had dreams to drop in one of the bolt in 5 speeds, financially it won't happen right now. My good old Muncie M22 will go back in.
The question:
Its dirty, what would be the best way to clean off all the road grime and such?
Take it to a DIY carwash and spray it down?
Huge solvent tank?
Old Feb 6, 2013 | 11:19 AM
Belgian1979vette's Avatar
Belgian1979vette
The question:
Huge solvent tank?
pressurize wash. Close off the front and rear before you do or wrap plastic over it.
Garys 68's Avatar
Garys 68
Auto parts store degreaser, scrubb brush, and a hose.
The muncie is vented from the front bearing retainer, so seal the input shaft and bearing retainer to prevent water from getting in. Also seal the output.
Old Feb 6, 2013 | 11:48 AM
Raider74's Avatar
Raider74
Exactly what I was looking for, thanks guys!
Old Feb 6, 2013 | 12:34 PM
jnb5101's Avatar
jnb5101
use mineral oil, it will dissolve the old grease and won't damage the trans or seals.
Old Feb 6, 2013 | 12:41 PM
hugie82's Avatar
hugie82
If its an aluminum case for which I assume it is, use Eagle 1 mag cleaner for cast aluminum mags. It will have a warning on the bottle saying not to use on clear coat or polished aluminum. It will look like you sand blasted it will little to no work
To Cleaning Muncie M22
