Speedometer Rebuild
His name/company:
John
Redline Gage & Clock Repair
469 Windy City RD
Humboldt, TN 38343
800-375-2310
He will replace your 85mph speedo with a 140mph if you want to go up. He charges 60.00 to do so, and you have to send in your old speedo for a core. If you choose not to send in your old as a core, he will charge you around 300.00 for the core. So it would be to your advantage to send in your core, as you don't need it anyways.
He rebuilds the cores, and uses brass bushings instead of nylon. GM started using nylon, but they don't last.
He sends you the speedo, and can tell you how to install. He also can re-calibrate if it does not match your cars gears.
I just send mine back for re-calibration. If you start changing your speedo gear in the trans, most likely you will also have to change the driven gear to match the speedo gear. It is much simplier to take the speedo out and have it calibrated to your car.
John will have you take 4 readings. You will need to have or find a friend that has a GPS that reads MPH.
The readings are
Car GPS
30=
60=
90=
120=
He recalibrates for free, you just have the cost of shipping it to him. He pays for shipping back. You have to ship him your core, but not until you get the replacement speedo, and you have 30 days to do so. So what I did, was ship my core back with the replacement and GPS speed readings for re-calibration all in one package.
The only thing I seen that was off, was the crossflags on the speedo. They are the markings of a 79 or below, and if replacing the speedo in an 80-82, the flags are different, but not that noticeble.
That inclucded shipping to you. Yes, a person can re-build them, but finding the parts is the problem. If a person finds the parts, then he has to know how to re-calibrate after the re-build.
