Swapping LS in my 78 vette. I have a lot of room behind the front passenger fender well since adding the vintage air. I need to run a bigger line 3/8 from the tank to the engine anyway? I can then use the original fuel line as the return to tank. This would provide a little better access to pump and regulator if I have fuel problems down the road.
Does the fuel pump have to be located back by the tank? That seems to be the most common but why?
I am also adding the Corvette regulator filter. Would an additional fuel filter harm flow if added back by the tank?
EFI pumps do not like to draw (suck) They are best kept close to the tank and below the outlet so that they are gravity fed. We just finished an EFI conversion on a 72 Coupe and used an LS1 Camaro fuel pump module with a flange kit from VetteWorks.
Rob
Absolutely what he said!
Put the pump in the back; make sure it has a pre (100um) and post (10um) filter. Proper size filters will not hurt the flow of fuel.
IMO, the fuel regulator should be after the fuel rails to ensure proper pressure
Enjoy
The pump included in my Holley Pro-Jection pulled thru the stock unit on top of the tank for years. It was mounted on the frame rail back by the tank though
I concur, electric pumps push fuel from the tank {most pumps are inside the tank} or mounted as close as possible...They are not as effective pulling as good as they push....
The pump need to be lower than the tank and as close to it as possible.
I originally mounted an external pump to the right rear frame rail for my TPI. It worked well, but I was not happy with the noise/vibration (I used all of the supplied rubber mounts and foam sleeve).
I was eventually annoyed enough that I dropped the tank and installed an in-tank pump. (If interested, see my write-up with photos on the Forum). Your 78 tank matches the configuration of the 82, that came with an in-tank pump. With an LS swap, you're already spending a lot of time and money - get the 82 parts, put it into the tank, and do it right.
Will consider this in tank pump. http://www.vetteworksonline.net/cata...roducts_id=108
Why should I run a new fuel line up front when the old steel line looks ok. I can run some cleaner through it nd add a filter on the other end.
Location answered on LS1tech
You can use the stock line, but the connections and flexible line need to be rated much higher than stock, ~60psi if after the regulator, or ~100psi if before regulator. I used stock late model nylon fuel lines.
Going to use the dorman 3/8 nylon line and the vetteworks fuel pump adapter for LS.
