Parking Brake Light
Old Feb 9, 2013 | 01:23 PM
rep69's Avatar
rep69
Default Parking Brake Light
My 1969 parking brake light on the instrument panel will not go out. When I pull up on the handle the light gets brighter. I do not hear or feel any dragging when I drive the car. I checked master cylinder and the fluid was at the top in the front half and down about 1/2 in the rear compartment. I filled the rear to match the front and drove car again. The light remained on . The brakes seem fine. Firm pedal. Any suggestions? Thanks
Old Feb 9, 2013 | 04:19 PM
'75's Avatar
'75
The brake valve on the frame under the mastercylinder has a switch to indicate brake failure that will turn on the same light. Try unplugging the wire there to see if the light goes off.
Old Feb 9, 2013 | 05:15 PM
rep69's Avatar
rep69
Thanks for the reply. I will look to see if I have a wire. I do know that there is the proportioning valve in the system. Could that be causing my problem?
Old Feb 9, 2013 | 06:19 PM
U17's Avatar
U17
I had a similar issue ,, http://forums.corvetteforum.com/c3-t...-light-on.html
Old Feb 9, 2013 | 09:45 PM
rep69's Avatar
rep69
I will look into the distribution block wire. I see no fluid leaks in the system.
To Parking Brake Light
