Borgeson problem
Old Feb 8, 2013 | 03:36 PM
peterbuchberg's Avatar
peterbuchberg
Default Borgeson problem
hi. Iam installing a Borgeson steeringbox on my 73 vert. the problem is that the steering box dont line up with the steering collumn. the box sits an inch lower than the collumn and in an different angel.the steering box boltpattern are exactly the same as in the frame. anyone seen this before? peter
Old Feb 8, 2013 | 03:54 PM
qwank's Avatar
qwank
It's possible the bracket on the box moved before they welded it on, or you have some extra tall body mounts.
Old Feb 8, 2013 | 04:07 PM
peterbuchberg
I dont think its the body mounts,because they are the same as before I swaped to Borgeson and the old box were fitting just fine..maby the welding. I have been searching this forum but nobody seems to have problems installing the Borgeson conversion kit.
Old Feb 8, 2013 | 04:10 PM
qwank's Avatar
qwank
it's possible it is the welding. if you do a search there's a thread on someone who got a mis aligned bracket and Borgeson was giving them a hard time about. Mistakes happen, My Borgeson packaging had the Corvette part number on it but had a Tri-five gear inside the box. I had to send it back and get another one. my second one was perfect.
Old Feb 8, 2013 | 06:37 PM
72LS1Vette's Avatar
72LS1Vette
There is a fair amount of play in the lower steering column bracket mount. You could try loosening the column brackets and see if the shafts align better.
Rick B.
Old Feb 8, 2013 | 06:53 PM
peterbuchberg
It align a little better. but the angle gets worse. its not straight at all.
Old Feb 8, 2013 | 08:19 PM
tarheeljww's Avatar
tarheeljww
I installed one last year and had the same problem.......my fix was, I went back to Borgosen and they sent me a universal joint that fit and worked great.......They took back the stock rag joint as well....
Great to work with and I love my steering now....
Old Feb 9, 2013 | 06:54 AM
oldalaskaman's Avatar
oldalaskaman
this one
Old Feb 9, 2013 | 08:27 AM
peterbuchberg
Originally Posted by oldalaskaman
this one
picture?
Old Feb 9, 2013 | 09:15 AM
texaswilkins's Avatar
texaswilkins
If you loosen the three mount bolts on the box is there any play there?
Bill
Old Feb 9, 2013 | 09:44 AM
peterbuchberg
just a little play, but then the box will hit the frame. I have mailed the pictures to Borgesen and they will look into it on monday. I think the universal joint will do the trick but anyway, something is wrong with the box I´am doing the hole engine bay, steering and suspesion this winter. here a pic of the 350.
Old Feb 9, 2013 | 05:22 PM
tarheeljww's Avatar
tarheeljww
Sorry, cant do a picture as my car is in the shop getting primed to paint.......As I remember the install, I had a few degrees of movement in the box per the bolts, and then added by drilling out the holes in the frame just a bit size or two and then I loosened the steering column and had a few degrees there as well.
The combination of those two AND the universal joint made mine work......
The steering is so precise and resposive now compared to the stock unit........Before I spent the money, I had completely rebuilt the stock system from steering box to drag link, and was hugly disappointed with the results.......1" of play at steering wheel.
Adding the Borguson was like night and day...
Good luck.
Old Feb 10, 2013 | 01:35 AM
iokepakai's Avatar
iokepakai
Using a Borgeson box with a SS U-joint,Borgeson # 114350.Been working great since 09....No leaks since upgrade!!
Old Feb 10, 2013 | 08:17 AM
manfroni's Avatar
manfroni
I'm having the exact same issue. I installed the box a couple of years ago and only drove it 100 pr so miles. The box has a lot of play in it, there is slop in the box. There is a huge difference between the steering input and the movement coming out of the box. Injustice 100 mile the rag joint was all torn up. The allotment is off about an inch. Open to any ideas.
Old Feb 10, 2013 | 08:50 AM
aaroncorvette's Avatar
aaroncorvette
Mine lined up fine, just the rag joint fell apart in less than a year so I got their solid uj and it's sweet now.
To Borgeson problem
