Removing rear end diff crossmember
Old Feb 9, 2013 | 02:14 PM
Mario Barrios's Avatar
Mario Barrios
Default Removing rear end diff crossmember
Have my rear suspension out and in progress.. figured I would remove the rear end and have it checked... I have the driveshafts all off... all ready to drop. I removed the 5/8 bolts from the crossmember at the rear. It won't budge. I tried a pry bar. No luck. Seems the rubber is stuck on there good. Haven't had any bad rusty bolt issues as this California car has been easy on me that way.Sooooo...any handy tricks?
Maybe I should leave it alone but everything is apart right now. What do I check for maintenance while I'm under there? The rear end was pretty dirty on the entire right side so it would be nice to make sure I'm good. How far should the side yolks move in/out? Is are c clips something that should be changed? Seals?
Old Feb 9, 2013 | 03:07 PM
Manuel Azevedo's Avatar
Manuel Azevedo
I needed a crow bar and alot of Kroil penetrating oil to get mine down. If your not going to replace the bushing on the cross member leave it alone.
Sounds like you need to replace some seals on the rear end for sure. I would take it completely apart my self to check clutches and all. The side yokes should be less than .015 in and out movement. I would also drill and tap a hole in the bottom of the case while it is apart to allow draining the oil later.
Old Feb 9, 2013 | 03:08 PM
edk136's Avatar
edk136
I just did this using a 3-jaw puller. A 2-jaw puller will make the job easier though. Just put some pressure on it, spray some PB Blaster, let it sit and it will pop off. Mine took a couple of minutes of constant pressure using the puller method.
Old Feb 9, 2013 | 03:27 PM
BKbroiler's Avatar
BKbroiler
Before you drop that crossmember with a puller or whatever, put those two 5/8 bolts back in partially. They will keep the whole thing from dropping like a rock.
Old Feb 9, 2013 | 03:34 PM
edk136's Avatar
edk136
Yea, what he said
Old Feb 9, 2013 | 04:28 PM
Mooser's Avatar
Mooser
Here's some good tips
http://forums.corvetteforum.com/c3-t...l-removal.html
I used two chisels but it seems lots of people have luck with the gear puller method
Mooser
Old Feb 9, 2013 | 09:21 PM
Mario Barrios
Default Figured it out
Ok...so one side popped off without too much nightmare using a pry bar. The right side though would not budge.
SOLUTION:
I used a bolt and a 3/4 nut. Cut the bolt down to where the bolt fit between the two pieces of steel I was prying. (right behind the bushing)
Then I simply held the bolt with a wrench and turned the nut with another wrench and it spread the parts far enough that I just had to put the pry bar ahead of the bushing and give it a little love and ....pop!
I didn't get a photo as I was doing it but here is one showing the bolt and where I placed it....hope it helps someone else
Old Feb 9, 2013 | 09:27 PM
Mario Barrios
Default oops here's the pic?
Ok my first attempt at including a picture...hmmmm let's try this:
Old Feb 9, 2013 | 09:33 PM
Mario Barrios
Default Picture is the hard part
Cant seem to get the pic thing down...did a search in FAQ and thought I got it but no pics.....Help sigh.....
Old Feb 10, 2013 | 12:42 AM
edk136's Avatar
edk136
Well, at least you got it out !!! Another way to do the job
Old Feb 10, 2013 | 09:04 AM
Mooser's Avatar
Mooser
When you copy the image from photobucket, copy the one that is called img code
Basically it needs the [img] and the [/img] around the web location of the picture
Old Feb 19, 2013 | 12:17 PM
rickwilt's Avatar
rickwilt
Cruising
Default Rear End crossmember removal the easy way
Old Feb 19, 2013 | 04:59 PM
Mooser's Avatar
Mooser
That looks vaguely familiar
Mooser
To Removing rear end diff crossmember
