front bumper
Old Feb 11, 2013 | 10:24 AM
RRROBB's Avatar
RRROBB
Default front bumper
I am currently in the process of replacing my front bumper cover on a 1977.
what are potential problems of notreplacing the honeycomb behind the cover?
Old Feb 11, 2013 | 01:49 PM
Learning_Curve's Avatar
Learning_Curve
Is the honeycomb damaged? Are you leaving the old in place, or just leaving it out?
If you go with a fiberglass bumper you can do without it, but if you use urethane it's needed to give the bumper its shape.
Old Feb 11, 2013 | 01:52 PM
RRROBB's Avatar
RRROBB
Honeycomb is not damaged. I just want to leave it out to make installing new fiberglass bumper easier.
Old Feb 11, 2013 | 05:20 PM
Learning_Curve
You should be fine. The outer bolt that hold the honeycomb in also retains the metal bumper to the frame extensions. You have to remove the bolts from the honeycomb or pick up some of equal size at the hardware store. On mine they are "captured" and aren't made to come out of the honeycomb.
Or you could trim the honeycomb down so it doesn't interfere with the fiberglass bumper. It could give minor protection to the front of the car in a collision, but nothing will save that fiberglass bumper if it's hit.
To front bumper
