Do you prime your oil filter?
Old Feb 11, 2013 | 08:13 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
Always have, I usually set it on the garage counter and fill it 3/4 full and then rub my finger around the o-ring gasket to lube it. I do this before taking the old oil out. By the time I'm ready to install the filter, it's usually dry again and I add more oil. The paper filter takes time to absorb the oil, thats why I do it first. Just the way I do my oil changes.
Old Feb 11, 2013 | 08:18 PM
billcarson's Avatar
billcarson
yet another thing to worry about.
Old Feb 11, 2013 | 08:27 PM
ajrothm's Avatar
ajrothm
Yes, I always do on all my cars and bikes... Makes a noticeable difference on how fast they pick up oil pressure after the oil change. No reason not to...
Old Feb 11, 2013 | 08:36 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Never have. Part of the reason is that most of the cars that I've owned had horizontal ( or nearly so) filters. They spew when you unscrew them so I don't imagine they'd be much better going on.
Old Feb 11, 2013 | 08:56 PM
DRIVESHAFT's Avatar
DRIVESHAFT
I always fill the oil filter, but I never bother with oiling the o-ring, at least not as part of an oil change.
When the old filter comes off, the sealing surface of the engine block always gets coated with oil.
Old Feb 11, 2013 | 09:00 PM
johnt365's Avatar
johnt365
I don't. But I see no reason not to. On one hand, it takes 20 seconds to fill the filter. However, I don't think it matters either way.
We could start another thread called "Do you use hand sanitizer after you touch the pump at a gas station?" The dispenser is right there most times.
Its the same deal, it only takes 20 seconds and is a wise precautionary measure, I am sure there is a germ to be killed on that handle. However, somehow humans lived without alcohol gel for thousands of years, so fill yer filter if you have the time.
Old Feb 11, 2013 | 09:03 PM
TedH's Avatar
TedH
I always fill my oil filters.
Old Feb 11, 2013 | 09:04 PM
roadblock69's Avatar
roadblock69
Always have and will continue to do so. Just makes good sense to have oil pressure as soon as possible.
Old Feb 11, 2013 | 09:07 PM
3JsVette's Avatar
3JsVette
Always!
Old Feb 11, 2013 | 09:12 PM
U17's Avatar
U17
Maybe wayyy off base ...but we give aircraft engines 30 seconds to indicate oil pressure .... There is still oil in /on the walls of a engine after draining .... But it does not hurt to "prime" the oil filter...
Old Feb 11, 2013 | 09:15 PM
gcusmano74's Avatar
gcusmano74
I believe in it. I always fill the oil filter before installing it.
My daily driver ('96 Crown Vic) now has 243,000 miles, my wife's car ('96 Volvo 850) 177,000 miles, and my Corvette ('74 smallblock convertible)has 171,000 miles. I use the Chevy medium truck filter on my Corvette. The NAPA/Wix 1794.
Old Feb 11, 2013 | 09:41 PM
Blue79's Avatar
Blue79
Never did. Now I believe I will. Thanks for the input!
Old Feb 11, 2013 | 10:02 PM
  #33
Mr.Green's Avatar
Mr.Green
I always lube the o-ring, no priming. I run the engine for a minute, shut it off and top off the oil.
Old Feb 11, 2013 | 10:56 PM
  #34
wcsinx's Avatar
wcsinx
It makes no difference. The (abstract) oil train is pan->pump->engine->filter->pressure sender->pan. Yes, I'm leaving out a chit-ton of important details, but the gist of it is the journals are pressurized before oil reaches the filter & sending unit.
You are not increasing the length of time for your engine to have adequate oil pressure. You are simple increasing the length of time it takes for oil pressure to register on the sender.
Old Feb 11, 2013 | 11:06 PM
  #35
DRIVESHAFT's Avatar
DRIVESHAFT
You might want to re-check that order.
Old Feb 11, 2013 | 11:07 PM
  #36
1977stroker's Avatar
1977stroker
Not the exact topic but interesting conversation and I had forgotten about this. Many years ago we had a bet in shop class. We had an old English Ford. The shop teacher drained all the oil out of the car. We all wrote down our guesses on how long it would idle before the engine seized and quit. I can't recall my guess. The engine idled all through shop class and the next morning we found out how long it ran. Over 5 hours, with absolutely no oil and the drain plug removed. That still shocks me and I would never believe it.
Old Feb 11, 2013 | 11:11 PM
  #37
LT1driver's Avatar
LT1driver
yes on all my vehicles
To Do you prime your oil filter?
Old Feb 11, 2013 | 11:20 PM
  #38
drwet's Avatar
drwet
Originally Posted by MrJlr
And check that the old o-ring came off with the old filter!
Ask me how I know to do this!
(I can finally laugh about it now.)
Old Feb 12, 2013 | 12:10 AM
  #39
ajrothm's Avatar
ajrothm
You are not correct on your flows..
Pan - pump - filter - galleys.
It will most definitely prime the system faster with the oil filter full...
Old Feb 12, 2013 | 12:33 AM
  #40
wcsinx's Avatar
wcsinx
I stand corrected then... not sure what engine(s) I was thinking of.
Still, have never primed an oil filter in any gen 1/2/3, have driven hundreds of thousands of miles on several of them, and have never experienced any premature journal bearing wear/failure. *shrugs*
